Question about SMC Universal Wireless Broadband Router ( smn2304wbrpag  )
Please help my router has never given me problems, know at my new adress it is, 3 lights blink in the left side of the router witch is fine, and on the right side there is a green light on the top and a orange on the bottom, its says speed on the side of it, im not connecting to the internet through the router, but staight to my modem im fine, it says on my network conections that its connected, but i cant get trough to the internet, and some times it says low or no conetivity. whats wrong with my router?
    Problem Solver:
  • 12 Answers
Need more info: You indicated that you moved. 1. Did you change internet service provider? 2. DSL or Cable Broadband? 3. If DSL, what type of modem? This info will help paint a better picture of the problem.
Posted on Sep 26, 2007
SOURCE:
1999 buick lesabre my right signal doesnt blink it stays solid , my left turn signal blinks fine i have to manually blink the right side every turn , i put the hazard lights on and the front left and right...
The easiest thing for you to do would be to replace the bulbs that are on that circuit. You should have one or two bulbs with a double filament, one for the brake and turn signal and one for the tail light.
If that does not fix the problem, someone will need to check the circuit for power from the turn signal switch. It takes all of the lights on one side to make the turn signal flash.
May 16, 2013 | 1999 Buick LeSabre Custom
My DIR-628 router is no longer connecting. My comcast modem is fine. Beside the D-Link symbol,, there are 2 lights working. The first from the rright is the circle with a line though the top. The other id...
Resetting router to factory defaults should fix this.
NOTE: Reseting the router to the factory defaults will delete any changes you have made to the router, including any security settings.
You will find reset button at back of router. Near power button. Press and hold the button for 10 secs.
Apr 12, 2011 | D-Link DIR-628 Wireless Router
My printer status shows as offline. I have spoken with Samsung technicians on their 1-800 number for about 3 hours and nothing they have done has worked. Please help. Debra
I had exactly the same problem.
The IP-adress on your printer may change if your printer or network router is switched off. Enter the printer network setup from your printer display and print a network konfugiration report, then go to your computer, open the printer properties from the control panel and check the port settings for your printer. If the ports IP-adress don't match the printers, you'll need to add a new port vid the same adress as your printer. Good luck...
Jan 20, 2011 | Samsung CLX-3170FN All-In-One Laser...
Pease help...i have a belkin wireless modem/router.model F5D8636 My provider is bigpond we have 2 new laptops which keeps asking for a security key no. I dont have 1 so neither laptop can connect to...
Dana on the PC that can connect to internet open the start menu and see if there is netwirk button to klick on. If so click it and see if it shows your Belkin Router icon if it does right click the icon and you should see a option to go to the router web page witch should look something like this.
See first pic below.
Find the security section on left side and go there. Should look something like second pic below. You will see the security key no in the password slot.
You can also get to the routers web page by typing its ip adress in the internet browser if you know your PC's ip adress (example 178.162.5.9) the routers ip will be the same but use a 1 where the 9 is. Hope I helped you good luck.4a682e3.jpgcae57f2.jpg
Sep 17, 2010 | Belkin Computers & Internet
I have a belkin g wireless router #F5D7234-4-BC, i have 3 computers and a ps3...2 of the computers and the ps3 connect fine to the internet wirelessly...i got local only on one computer i am having the...
change the security type to 64bit WEP... and have your password as 10 digit number...
also change the ssid to a single word with no spaces in between....
right now your password is wpa/wpa2... this is not compatible with certain computers....
Aug 23, 2010 | Belkin (F5D7231-4) Wireless Router
Not getting wireless connection
Unfortunately Not All the details are not given in this
Any way
Try This
Open RSP By typing 192.168.2.1 on the Address Bar of Internet Explorer
On the Left hand side underneath Wireless Click Wi Fi Protected Setup
Leave the Password Blank and click Submit
Disable it And Apply Changes
Jan 06, 2010 | Belkin F5D8236-4 Router
'86 Shadow right front turn signal doesn't work
you may want to trace your wires to that light and check to make sure that your ground wire for that side is clean and tight that may take care of your problem all together
Jun 07, 2009 | 1985 Honda VT 500 C Shadow
Power problem for phillips 42 plasma 42pf7321d/37
That blink don't mean nothing. Measurements need to be made. Don't just buy the board troble shooting would need to be done to see witch board is bad. Also look on the fron of the set and see how many time the led flashes. That wher your error code comes from..
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Open Questions:
See all SMC Universal Wireless Broadband Router Questions
SMC Universal Wireless Broadband Router ( smn2304wbrpag  ) Logo
238 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
