Question about Chanel Clothing Accessories
I need a screw for the front of some Chanel sunglasses model number 4117-B. They were purchased several years ago and the screw is a octagonal shaped with a crystal or diamond in the center. It is very short and goes through the lens and into the support frame.
  • 1141 Answers
SOURCE: How to Choose a Sunglass Frame? What should be
Your first considerations should be the shape of your face and the shape of the frame.
Choose frames in a color that enhances your skin tone.
Frames are made with different materials. Metal frames are easy to adjust and are not likely to interfere with your vision, but they are usually more expensive and less durable than frames made from other materials. Nylon frames are inexpensive, lightweight and durable, but are not likely to be adjustable. Acetate frames are often found on stylish glasses and come in a great variety of colors.
Consider wraparound lenses. Wraparound lenses offer the best protection, because they block light on the sides and provide extra protection from the elements.
Check the fit on your nose. Rubber or plastic nose pieces are less likely to slip down your nose if you sweat.
Posted on Nov 07, 2010
  • 1141 Answers
SOURCE: Small sunglasses frames? Help? There are a lot of
It is rather difficult to answer this question without knowing what your face shape is so I would recommend going to the first link to determine that and get started that way. If there is a style that could be recommended for many it would be the aviator and not the large ones. The second link is to a small aviator in Champaign by Serengeti, it has a 53 eye as you can see in the last link (which is small for sunglasses) and a very attractive look. Other than that the best thing to do is go to a quality sunglass or optical shop and try on everything until you find something you like. If that is not an option there are also several online tryon's where you download an image of yourself and can try on the different frames.
1. http://www.framesdirect.com/face-shape.asp 2. http://www.framesdirect.com/framesfp/Serengeti-tcrikj/lb.html 3. http://www.serengeti-eyewear.com/index_en_na.cfm
  • 103 Answers
SOURCE: My roberto cavalli sunglasses continue to loose
hi
i understand ow much irritation it must be to you,please try approaching any other dealer with your lens if you are under warranty period i think you get it replaced .if it not under warranty and if the dealer dont stand by it .please try visting site which dealer with sunglasses replecement parts i think they can provide you solution and it will cheap
thank you
Posted on Dec 28, 2010
jyackle5
  • 8197 Answers
SOURCE: I dropped my pair of
To get parts for the glasses you will need to go to the link below.
http://www.theglassescenter.com/online-shop.html?page=shop.product_details&flypage=flypage_new.tpl&product_id=2275&category_id=82
Posted on Jan 22, 2011
jyackle5
  • 8197 Answers
SOURCE: I own bridgetender grey lens
Sorry we do not sell frames for glasses you can try the link below to order the polished frames. We can only help you fix them or give you a source for parts.
http://www.sunglassreplacementlenses.com/
Posted on Apr 11, 2011
I have a Euro-Pro that my daughter purchased several years ago and gave to me. I have no manual and there is no model number so that I can request a manual. What do I do?
There should be a plate on the machine that lists power voltage. This normally shows model number and serial number.
There are a number of machines listed as Craft n Sew and there are manuals. Also look at the Video Tab.
Euro Pro Google Search
Nov 22, 2016 | Euro-Pro Sewing Machines
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
Tip
Tips on how to Get Deals on Sunglasses
Looking for cheap sunglasses? Sunglasses are great for several reasons. They can protect your eyes from the sun's UV rays, keep your from squinting in the bright light, and they can create a bold fashion statement. While the first two are reason enough to get some sunglasses, don't forget about the latter. When you're looking for your own sunglasses, you'll want to make sure that they look great. Yeah, you can get some shades at your local drug store, but do they look good, no, they don't. They often look cheap and have bad style and design.<br /><br /> <br /><br />Luckily, you can still find great glasses without having to spend loads of money. There are several great ways that you can do this. First, you can find cheap sunglasses by searching for sales on your favorite brands. Whether you like Gucci or Chanel, you can find deals if you look hard enough. For instance, outlet malls are a great source for discounted designer sunglasses. <br /><br /> <br /><br />If you don't live in an area that has an outlet mall, you still have other options. Did you know that you can save more than fifty percent by purchasing replica sunglasses instead of their designer counterparts? Some people shy away from this because they think they're getting something cheap that will fall apart. On the contrary, designer replica sunglasses are well made and follow the trends perfectly. The only difference is that they aren't made by famous designer brands. If you want to save a lot of money while still looking good, then replicas may be the answer.<br /><br /> <br /><br />Just like with other products, some replica sunglasses are made better than others. You'll want to purchase them from a company you can trust. While there are a lot of great website out there, two really stand out. First, there's Impostercity.com. This website carries a lot of the best brands when it comes to sunglasses. And no pair is over twenty dollars. They have a lot to choose from, so don't forget to spend some time browsing.<br /><br /> <br /><br />If you're more interested in what celebrities are wearing, you may want to check out Voguewear.com. They carry some of the best glasses that you've no doubt seen on the red carpet. All of their glasses cost $19.94. If you're trying to think of a gift for a teenaged relative, this is the perfect place to start looking. As you know, kids like to emulate their favorite musical artists and movie actors.
Missing pearl on chanel 6038-H
If they are a year or less they should fix those under the "year warranty" through the manufacturer.
Nov 20, 2013 | Chanel Clothing Accessories
Tip
Fashion Sunglasses tips
You want to look great going into the summer season. What are the latest sunglass trends happening today? The good news is that there is a lot of option for you to select from. You can choose sunglasses you want to wear and know that they are in style. From Hollywood sunglasses to the biggest names like Gucci, Ray Ban and Aviator, sunglasses continue to be the defining element in style.<br /><br /> <br /><br />Big May Be Better<br /><br />One of the sunglass trends you will see a lot of in the coming months is the big sunglasses. Oversized sunglasses, as people call them, are a good option for many people anyway. Because this is one of the largest trends currently in sunglasses, you are going to see them available by many of the best manufacturers.<br /><br /> * D & G Dolce Gabbana Sunglasses<br /> * Coach<br /> * Burberry<br /> * Chanel<br /> * Prada<br /> * Versace<br /> * Tommy Girl<br /><br />Each of these designer sunglasses feature at least one, if not more, models in oversized specs.<br /><br /> <br /><br />Oversized sunglasses work best for those who have a round face or triangular face. Be careful wearing them if your face is small as this could cause them to take over, giving that very strange "bee" look to your face.<br /><br /> <br /><br />Vintage Is In<br /><br />Another style that is a popular sunglass trend is the vintage sunglasses. Vintage sunglasses can come from a variety of eras, but most commonly found are those from the 1930's and later. Or, you could choose retro sunglasses, which are sunglasses from the 1970's and on. Don't worry; even as vintage sunglasses go, you will still find them much more modern than the actual sunglasses of those years.<br /><br /> <br /><br />Again, ranges of designers do offer the ideal vintage trend in sunglasses:<br /><br /> * Diesel<br /> * Burberry<br /> * Dolce & Gabbana<br /> * Ray Ban Wayferers<br /> * Kanye West Shutters<br /><br />Aviator Sunglasses<br /><br />Yet another popular sunglass trend is the aviator sunglasses. These have been popular for some time but continue to be the type of sunglass that everyone wants to be seen in. They are available through a number of manufacturers, too, including:<br /><br /> * Armani<br /> * Prada<br /> * Ray Ban<br /> * Revo<br /> * Dolce & Gabbana<br /> * Ralph Lauren<br /> * X Loop<br /> * Versace<br /><br />Sunglass trends can change yearly so be sure to stay on top of them. They key is to really find the type of sunglasses that fit your face correctly and that you love. Trends are often along the lines of celebrity sunglasses, too. If you see your favorite actor, musician or sports athlete wearing a pair of must have
I need replacement lenses for ch5076h
Lydia31 The Chanel 5076 is discontinued but we make aftermarket lenses for this model that are better than the originals. They are $39.00 for the pair. Contact us at www.sunglassreplacementlenses.com
May 10, 2011 | Chanel CH 5076H Sunglasses
Are Armani Exchange sunglasses made in China?
Yeah, China is the manufacturing centre. Some of brands of sunglasses and brand sports shoes, designer handbags all also made in china.
Clothing Accessories Logo
42 people viewed this question
Top Chanel Clothing Accessories Experts
Da Doc
ray gallant
Are you a Chanel Clothing Accessory Expert? Answer questions, earn points and help others
