My Kenmore air conditioner model number 253.70051 hardly blows any cold air
Krazytech
  • 725 Answers
SOURCE: E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Posted on Jul 26, 2008
  • 340 Answers
SOURCE: my air conditioner is not blowing out real cold air
have it cleaned sounds like symptoms are like a dirty unit .
Posted on Jun 22, 2009
  • 44 Answers
SOURCE: My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Posted on Aug 21, 2009
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
heatman101
  • 43501 Answers
SOURCE: Danby DPAC7599 Air Conditioner is not blowing cold
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
Window airconditioner cycling on and off too much but blows cold when running
Eliminate the possibility that the cold air from the unit is not blowing directly on the thermostat temperature sensor.
The air conditioner may be extra large in capacity for the space being used for.
Aug 20, 2014 | Kenmore Heating & Cooling
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
I have a sears kenmore air Conditioner about 10 years old. Not sure the model number. It stopped blowing cold air a few days ago and in cleaning the filter the hold down elastic string got caught under...
What came loose was the heat sensor bulb, it is snapped into a retainer clip and connected to the unit be a very small copper tube.
This is not the cause. Most likely cause is low freon, bad compressor or the capacitor
Jul 27, 2014 | Kenmore Sears Air Conditioner 74054 Clean...
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Kenmore Window A/C model 580.76129300 - no cold air
Look and see if the compresser is kicking on if not see if it has ref
Aug 20, 2012 | Heating & Cooling
The window unit I have has stoped blowing cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
heatman101
Wall unit will not blow hard at high speed
try to clean your filters and adjust your setting on the remote
Jun 06, 2010 | Carrier 36KCARMS Air Conditioner
Kenmore refridgerator not blowing cold air.
You need to replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . It is easily replaceable . Take your model number with you when you get the part kit , so you get the correct replacement . DO NOT use a 3 in 1 hard start . This item is used by inexperienced technicians , and will only last a short time . Get what is called for , for your refrig .
Nov 04, 2009 | Kenmore Refrigerators
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
