Question about Genius Traveler 6000 USB
Genius traveler 6000 mouse - how to take it apart?
How to fix genius traveler 6000 scroll problem
there is in side mouse scroll knob there is a rotary veryable that very-able not function properly just change that very-able
Jul 14, 2014 | Genius 31030051101 - Traveler 6000 Mouse -...
Why Genius traveller 6000x Brand New WONT WORK?
you may need to first add a bluetooth device to ur pc/laptop.
There's usually a "synch" button on the mouse..check underneath where the batteries go..it may be larger, if built to follow the design of the mouse or it may be smaller if its "clearly a button".
You need to attach the bluetooth dongle to ur pc/laptop, then after the drivers install, press the synchchronize button on the mouse.
Jun 11, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
Where can I download a driver for genius mini mouse gm-03025a windows 7
I am surprised that Windows 7 would need a specific driver for your mouse. I couldn't find your model number but here is a list of all Genius mouse drivers. Perhaps one will work for you.
http://www.nodevice.com/driver/company/Genius/Mouse.html
May 24, 2014 | Microsoft Computers & Internet
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
How do I increase the range on my wireless microsoft 6000 keyboard and microsoft wireless laser mouse 6000 v2.0.
I have a Microsoft Wireless Notebook Laser Mouse 6000 that also has a very short range. The only solution I've found so far is to plug the receiver into a USB extention cord and run the cord toward the mouse.
Mar 04, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft Wireless Laser Mouse 6000 v2.0 Scrolling has gone awry
This may not be a solution for you but at least it may explain the cause of the problem. I recently had the same problem - the scroll wheel suddenly began to go crazy, jumping all the way to the bottom or the top of a document, or randomly skipping around. The unit was still under warranty, and Microsoft sent me a new mouse. Since they did not require me to return the old mouse, I decided to take it apart to see if I could find the problem. I found poorly soldered electrical joints to the optical sensor & LED which convert the scroll wheel movement to electrical signals. After I resoldered these connections the mouse worked fine again.
Feb 03, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
How do I open the Genius Mouse Pen to change the battery?
there should be a button type deal on the side somewhere above the buttons. push that in and pull the two halves apart.
Jan 03, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Wireless mouse not working
I worked this out last night! Click the button on the top of the dongle and the connect button on the back of the mouse at the same time and it works.
Richard
Oct 11, 2008 | Computers & Internet
Genius mouse model No gm-03025a reqire drivers for windows vista
The nearest item I can find based on the item number you provided is the Genius Mini-Traveler.
Vista Driver is located here:
http://download.geniusnet.com/2007/Mouse/ioCentre_v1.2.zip
Apr 29, 2008 | Computers & Internet
Genius Traveler 6000 USB Logo
44 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
