Question about Refrigerators
My Kenmore A/C model number 253.70051 hardly blows any cold air
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
dealt_soul
  • 296 Answers
SOURCE: blows only cold air
Check connection to heating elements. My have bad heating elements
Posted on Jan 19, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series model 110 60902990 wont heat
There are a few things you can check. You will need a voltage/ ohms meter. First thing you should check is that you are getting 240 Volts too the dryer. If the dryer is getting voltage, then you will need to check the heating element first. Remove the lower front panel usually held on by 2 1/4" screws. The element is located on the right side of the dryer (Looking at the front). Unplug the dryer, check continuity on the 2 terminals on the element, if there is continuity, the element is ok. Next you will need to start checking the thermostats. There is one thermostat and one safety stat on the side of the element housing. Both of those should have continuity also. If all three os those parts are checking out ok, you wil need to check the safety attached to the blower duct work directly below the drum. The easiest way to get to that safety is to remove the lint screen duct.Two 1/4" screws hold that on.
These are the most probably causes of your dryer not heating. Please contact me if you need more info.
If this helps you and you need to order the defective part, let me know and I can ship you the part also.
Hope this helps.
Vic
Posted on May 08, 2009
VOTIT
  • 2071 Answers
SOURCE: Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Posted on Jul 05, 2009
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
I have a sears kenmore air Conditioner about 10 years old. Not sure the model number. It stopped blowing cold air a few days ago and in cleaning the filter the hold down elastic string got caught under...
What came loose was the heat sensor bulb, it is snapped into a retainer clip and connected to the unit be a very small copper tube.
This is not the cause. Most likely cause is low freon, bad compressor or the capacitor
Jul 27, 2014 | Kenmore Sears Air Conditioner 74054 Clean...
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Kenmore refridgerator not blowing cold air.
You need to replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . It is easily replaceable . Take your model number with you when you get the part kit , so you get the correct replacement . DO NOT use a 3 in 1 hard start . This item is used by inexperienced technicians , and will only last a short time . Get what is called for , for your refrig .
Nov 04, 2009 | Kenmore Refrigerators
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Dec 01, 2007 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
