Question about Samsung HCL4715W 47" Rear Projection Television
Colors on my samsung projection tv are not aligned. how can i fix?
My projection samsung has a problem with the colors. It seems that the magenta color is not aligned with the other ones and the image has an aura. Is this problem fixable? Is it expensive? should i throw it away?
    Novelist:
  • 159 Answers
Any color gun has a value about 175 +- dllrs. to get the tv back to nornal one need to be replaced maybe two: Plus labor 250 average. An estimate can get you the best idea what to do.
Posted on Apr 24, 2009
The red lens on my projection screen dose not seem to line up right the picture is fuzzy and it will not moveback in alignment with the remote
Tv board call the Hyper board also known as a tv convergence board it is dead.Tv have any R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the the Hyper board also known as a convergence board will fixed tv picture convergenece problems.Tvs shops will cost u like $300-350 for parts and labors.
Aug 22, 2011 | Toshiba 57H81 57" Rear Projection...
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
Picture is unstable (jittery) colors (especially red & green) are smeared. Picture seems to have aprox. 4 horizontal not in line boxes.
Ur tv have a problems known as a convergence problems it dead.Tv have colors lines like R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Tv have a dead convergence board,board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv picture convergence problems.The shop,will coat u like $300-350 for parts and labors.
Jan 31, 2011 | Hitachi 61SWX10B 61" Rear Projection...
I have a Samsung HLN617w that has an awful buzzing noise that seems to be continuous and maybe from the lamp fan. Any suggestions on a fix?
This tv have a colors wheel is dying and worn out.The sound u hear buzzing,squiling or lound motor noises.The colors wheel require changing,because it dying and spinning off of it motor axis.Hire a tv Tech. to change the colors wheel,because it sit way inside near the Light Projection Engine it self,require take out many machanical parts even can come to the colors wheel itself to change it.
Nov 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
Image is out of focus. colors do not align
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jan 14, 2010 | Zenith R50W46 50" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung BP95-00142E Convergence Board changed still having a problem with the blue color
Actually the TOP Left blue corner cannot be allinged properly thru manual blue convertion.  Red is aligned correctly.
Oct 30, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
304 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
