Question about LG 60PC1D 60 in. Plasma Television
Lg 60 screen went black, but not completely. Lg 60pc1d
5 Suggested Answers
  • 92 Answers
SOURCE: LG SCREEN REPAIR
Front Screen?
Do you mean the filter glass or the actual plasma display?
If it's the filter glass, start looking for a 2nd hand one, they are almost £500 ($600), perhaps more for a 60". They are not just "glass", they have an infra red filter film on one side and a protective film on the other.
If you mean the plasma panel itself then unfortunately a replacement screen will cost you more than a new TV. You will not find a 2nd hand one.
I hope this helps.
Posted on Mar 28, 2009
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
eagle338
  • 4889 Answers
SOURCE: I have the LG 60PC1D plasma TV. The screen has
This problem is caused by faulty sustain boards(X-sus and Y-sus). This problem is usually triggered by malfunctioning buffer boards. Hence the first thing should be to test the buffer boards to see if they are ok before replacing the sustain boards. Unfortunately they cannot be tested by the end user as these logical boards sometimes require special tools to test. Have them tested by a tech , so that I can help you find replacements to fix it yourself.
Posted on Jan 03, 2011
spr1949
  • 1182 Answers
SOURCE: Our LG 42
Most probably the capacitors in the power supply have burst. Might need attention by a qualified service technician.
Posted on Aug 02, 2012
Factory reset lg tv model number 60pc1d please
You should have its factory remote control to do a reset to it. There is no other way to get into its service mode, and to make a reset. Contact the authorized service center for LG.
Feb 26, 2015 | LG 60PC1D 60 in. Plasma Television
My LG 60pc1d plasma starts to flicker on top after about a hhr of being on?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 26, 2015 | LG 60PC1D 60 in. Plasma Television
Model 60pc1d LG pedestal 60 inch
Contact the nearest authorized service center or dealer to LG at your town.
Feb 04, 2013 | LG 60PC1D 60 in. Plasma Television
Schematic diagram for power supplys LG 60PC1D-AA
I do not have the schematic, but have a testing / troubleshooting guide for the 60PC1D 1st and 2nd generation, which gives some good insight in organization and functionality of the power boards.
This is what we ourselves step on when repairing - LG often does not publish schematics for power boards and sustain boards.
contact us if interested
Sep 30, 2012 | LG 60PC1D 60 in. Plasma Television
LG 60 PC1D plasma tv flicker and lines in screen
Either the power supply (ALMOST NEVER JUST ONE BAD CAP...) OR THE MAIN.
Mar 28, 2012 | LG 60PC1D 60 in. Plasma Television
I have a 60in plasma tv and the top half of the screen is black, what could be wrong with it?
Hi Lorena,
Please confirm if the Brand and model number of your TV is LG 60PC1D, it will help diagnose accurately where the fault came from.
Jdvillanueva
Jan 11, 2012 | LG 60PC1D 60 in. Plasma Television
I have a 60" lg
The time taken to show picture is due to leakage of electrolytic capacitors in the internal power supply of the set,if you are technical person check and replace the capacitors in the secondary stage of power supply,ti will suerly solve the problem.
Jan 22, 2011 | LG 60PC1D 60 in. Plasma Television
61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Oct 12, 2009 | LG 60PC1D 60 in. Plasma Television
LG 60PC1D 60 in. Plasma Television Logo
19 people viewed this question
