Question about LG Verizon un251 Cosmos 2 MobiPhone- Black
The people I call can't hear me. They say I sound like I'm forty feet from the phone
I dropped my LG rumor 2 about 2.5 feet or 3 feet and the screen went blank and everything still works...but you cant see anything happening just hear it. HELP PLEASE!!!
Hi
The problem you are experiencing has to do with the screen of your mobile.All you need to do is to get to a phone store and get the screen of your phone replaced so your phone can work perfectly again.
GOODLUCK
Jun 25, 2010 | LG RUMOR Cellular Phone
Perfect level sounds very strange
Check the leveling feet on your machine. With the machine turned off, and with a small carpenter's level, check to make sure the machine is level front to back and side to side. Then give the machine a shake in each direction to make sure that the feet (which are adjustable). If the machine wobbles-even a little bit- adjust the feet until all 4 feet are in contact with the floor and the machine fails to wobble when pushed.
Rerun a load and see if the machine has stopped sending morse code...
you can also make sure that the fill hoses aren't banging into the machine or the wall during the cycle.
let me know if you have success!
Jun 01, 2010 | Washing Machines
Need to look at a manual for a Fortis B-42 watch
I have talked to Fortis and they will email you a manual if you need. Here is how to contact them on link below.
http://www2.fortis-watches.com/en/contact/index.html
Good luck and please rate 4 thumbs for the free answer
Mar 18, 2010 | Bulova Watch
Garage door opens about 8 inches and then revereses
Formula what? they have over forty different types. though sounds something like either limit switches may be faulty. Is this door new? Are there any odd noises from the motor?
Mar 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Do i have it hooked up correctly
If you have the line connected to the rear of frig. and the valve is on with no leaks you do have it hooked up properly. The water has to go through a series of solenoids and about forty or fifty feet of tubing before it reaches the door. This process takes a bit.Hold a glass under the water fill spout and press it in. If you can hear the sound then all you need to do now is wait. continue to hold the button until water comes out. dispose of the first few glasses of water and the first few drops of ice. this will allow the system to be flushed of all contaminants. Note that when an ice maker is new or not used much it will not make very fast. it usually takes about 24 hours to make the first drop. Hope this helps and good luck.
Feb 26, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Washer virbrates but is level
Ok, first check level at front, left to right should be level, then tilt the machine forward moving rear feet off the floor, dont use the console as it is fragile, grapple at the steel frame below. You should hear a sound of racheting, This is the rear feet adjusting, do this twice. Now if you dont hear this sound and the machine is new, check for a yellow plastic tab, shipping pin to remove, or you have a Cabrio or Oasis. If this dont work you will need to support the floor to stabilize the machine.
Aug 08, 2008 | Kenmore 22422 Top Load Washer
Volume too low
Download the latest driver from SMC corporation and update the phone as instructed.
Before, I couln't hear it ring from 5 feet away. Now I can hear it ring from the next room.
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&knowsPartNumber=false&productCategory=14&modelNumber=1564&partNumber=3564&downloadType=0&os=0
Sep 01, 2007 | SMC WSKP100 IP Wireless Phone
LG Verizon un251 Cosmos 2 MobiPhone- Black Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
