Question about Apple iPod shuffle MP3 Player
IPOD doesn't turn on
Hello, I also read that someones IPOD 80DB doesn't turn on, since today in the morning I'm having the same problem, and I talked to few guys from work with also have an IPOD 80G and they all had the same problems in a very short time after buying it.. It that a series problem? Anybody knows how to fix it, my friends got it changed
  • bail Dec 09, 2007
    It blinks green and orange
  • Anonymous May 18, 2008
    80G
The first thing that every iPod owner needs to know is how to restart your little MP3 player. Apple has a nice little tech note about restarting your iPod, and here's the gist of it:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
Posted on Nov 12, 2007
  • fanis1200 Nov 12, 2007
    i had the same problem with m8.this is the solution
SOURCE:
Model elefw408. How do I set it up?
[PDF]40 Full HD Digital LED TV - Webcollage Content Publisher
media.webcollage.net/.../89344b29-22c8-49d4-80db-2b1939698e05.pd...
Read all of the instructions before using this TV and keep the ... ELEFW408 ... Read these instructions - All the safety and operating instructions should be read
Oct 20, 2015 | Element Televison & Video
How much to fix ipod touch screen and where
Good morning, afternoon, evening or night; whatever time of day you receive this. You want to know how much to fix the touch screen and where to fix it? I want this solution to benefit you as much as possible. Having to pay for someone to fix your iPod touch screen should be your last result. I'm tell you some options you can try that may save you a few dollars and having someone to fix the iPod touch screen. I don't if this is the problem, but the touch screen may be locked. Automatically, the iPod touch locks when there has been no activity for a certain amount of time. To unlock the touch screen, press and hold the Home button or the On/Off/Sleep/Wake button which is located at the top of your device, and then drag the slider. If you want to set the amount of time before Auto-Lock activates, press Settings, General, Auto-Lock; then set your preferred time. If that doesn't fix the problem, you can try a system reset. To do this, press and hold the Home and On/Off/Sleep/Wake buttons together for approximately 10 seconds until the Apple logo appears on your screen. If this doesn't work, you can take your iPod Touch to your local Apple Retail store and have an Apple technician work on it for you. There will be a fee for diagnostic services. You can also contact Apple Technical Support or Online Service Assistant. For more contact information, go to this website (http://www.apple.com/support/contact/). I hope the problem is just a screen lock up and if you have to get a repair or replacement, it won't burn a hole in your pocket. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Apr 26, 2011 | Apple iPod touch
Lost the FM signal this morning, AM still works fine. all I get is static on FM with some intermittent what sounds like CB radio.
hello please check the rear of the radio as antenna could have come away from it hearing sounds like cb radio do you mean transmissions can you hear someone talking ,its probably someone near you that you are picking up
Mar 17, 2011 | Sony CDX-CA750X CD Player
IPod screen does not display and is all white but plays music
hello, Was someone messing around with the Contrast settings? If so, the Contrast may be set so low that you can't see the information on the iPod's screen. The only way to reset your iPod back to the factory defaults (including the Contrast setting) is to let the battery drain all the way out. Do whatever it takes to let the battery die then let the iPod sit overnight to be safe. Then the next morning, charge the battery and turn the iPod on. The first thing you should see is a screen asking you to select your language. If you can see your screen now, congratulations, this did the trick. If not, you probably need a new screen.
Apr 04, 2009 | Apple iPod nano
Ipod won't sync to Itunes
When you wiped the old computer and then reconnected to the new computer, it reformatted the player, causing data corruption. I would try all five of these suggestions, but first try uninstalling and reinstalling all Apple/iTunes software: Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Sep 08, 2008 | Apple iPod nano
Sep 07, 2008 | Apple iPod nano
My ipod doesnt powre on
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod nano. Try
these steps one at a time until your issue is resolved. If one of the following doesn’t
â Reset iPod nano. See “General Suggestions,” below.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod nano. See “Updating and Restoring iPod nano Software” on page 50.
Jun 16, 2008 | Apple iPod nano
Ipod 30 gig 5th generaiton question
Do the 5 R's:
These are for Nano, but they apply to all iPods:
installed.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 06, 2008 | Apple iPod nano
Middle of screen is blank
Your screen is probably damaged, and will need to be replaced, but try these:
installed.
Jun 02, 2008 | Apple iPod nano
Ipod
installed.
May 26, 2008 | Apple iPod nano
Apple iPod shuffle MP3 Player Logo
1,052 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Parshiv Luthra
Marvin
Marvin
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
