Goal3+ motherboard, sis761gx/965L chipset, 754 cpu socket. Powers up but monitor, mouse and keyboard will not come on.
    Problem Solver:
  • 7 Answers
Recheck the connections
Posted on Apr 24, 2009
Where do i find a software to flash my motherboard so a memory can work?(SIS761GX/965L CHIPSET)
Memory should work without flashing the BIOS. You either got the wrong RAM or something else is hosed.
Dec 26, 2009 | Computers & Internet
Just bought a new motherboard and i cant get the ethernet card to enable. The computer knows its there and lists it in the device manager with a yellow caution sign on it. The motherboard is a goal3+...
Let me guess... Tiger Direct special hehe
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=405&CategoryID=1&DetailName=Driver&MenuID=48&LanID=0
follow that link and click on down arrow next to USA in the SiS 190/191 onboard LAN driver section. Now just downloading them doesnt install the drivers. The download is actually a zip file that will need to be extracted. Once you extract the files goto the folder and look for an exe file to run. If there is no exe you will have to manually update the driver through the device manager.
It's probably a good idea to install all the drivers on that page for your system for optimal performance.
You can do it!
Oct 26, 2009 | Computers & Internet
I SEAMED TO HAVE LOST IMAGE FROM MY VIDEO CARD AFTER ADJUSTING MY SATA CABLES
- Re-check all internat and external connection.
- Remove and re-set VGA card
I this not solve, leave only minimal devices connected to MB (Keyboard VGA, CPU and RAM, disconnectt allother) and check image.
Oct 19, 2009 | Gigabyte GA-K8NNXP nVIDIA nFORCE3 CHIPSET,...
What is the battery number
Generic #cr2025 - Energizer #2032 Its a 3.0v battery
Oct 04, 2009 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
My CPU is starting but my monitor is not the light
First check your input devices, the keyboard & Mouse. If they are OK, i.e. no bent pins or try a working keyboard & mouse. If the motherboard beeps more than twice then remove the RAM from the slot, clean the contact points. If that too does not work check all connections as snug-tight.Remove all hardware accessories except for the HDD. Use the bootable OS disc and reload the OS..............sodeep
May 12, 2009 | Intel Asus P5GL-MX 800MHz FSB 915GL...
Downloding drivers
i have sony dvd rom and writer driver
Sep 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
PS/2 Keyboard not Working
ps/2 means the north bridge chipset is going ( just not totaly dead though ) in time you may notice the usb may not work at 2.0 speeds
Sorry nobody on this planet can repair a ps/2 unless another motherboard is purchased .
Aug 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
No External Speaker Sound
Hi jdnimrod,
This is not you're first post about the Foxconn mother board.
You have an issue with the PS2 keyboard as well. This Foxconn model ( 761GXK8 you listed ), is not 100% correct.
Please check this link:
http://www.foxconnchannel.com/EN-US/searcher.aspx?key=761GXK8
Find which is you're board.
Than post back into this answer.
It is important you run the exact CPU that is compatible with the mother board.
Foxconn's Compatibility chart for MB to CPU.
761GXK8MB-ERS/EKRS
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606271133082354761GXK8MB.htm
761GXK8MC-RS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200603210922432734761GXK8MC-RS.htm
761GXK8MB-KRS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606300744394666200606271143263290761GXK8MB[1].htm
I'll help you further once I know the correct mother board.
Mike
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
Computers & Internet Logo
1,570 people viewed this question
David Payne
David Payne
