Question about Topeak Joe Blow Ace Floor Pump
Guage needle fell off joe blow pro pump - Topeak Joe Blow Ace Floor Pump
Had the same thing happen. It turns out you can pry off the plastic ring around the dial, then remove the clear plastic window. I did that and just stuck the needle back on at 0.
Posted on Jun 04, 2014
The needle on my dash fuel guage started spinning around and around while I was driving. After an hour it settled but was reading wrong. After a few days of reading wrong I replaced the fuel pump with an...
first did you replace just the pump or did you get a complete assembly. the reason i ask is gm vehicles are notorious for there sending unit issues i have one currently that does the same. also on some aftermarket units they dont seem to work as well the delphi units are still available at most parts stores and not to outragious. hope this helps
Feb 03, 2011 | 1998 GMC Safari
Cant get the chain oiler to pump oil. Can hear it pumping
If it has oil and is not pumping it, then it is probably blocked by a wood chip that fell in to the oil when you opened the cap.
You need to blow it out with air, backwards.
Aug 26, 2010 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Worcester 24i junior boiler about 5 years old making banging noise and losing pressure thro overflow can you help.
its getting to hot /either your water level is low in the system /the circulating pump coupler could be broken; so water may not be circulating through the pipes, this will cause relief valve to blow ..air may be in the lines also/let me know if you need more info/good luck/joe/
what does the pressure guage read it should be reading 12lbs at the lowest an 30 at the highest/the relief valve will blow at 32 lbs this depends on how many floors or levels you have ..
Aug 25, 2010 | Heating & Cooling
I have a 1997 Dodge Voyager Ralleye and the speedometer needle fell off because the instrument panel shorts out once in a while and my wife smacked the top of the dash and it fell off...so I pulled apart...
with the needles off and the scanner set to calibrate the speedometer and all the rest of the needles need to be installed at 1/2 full range with the system on unless otherwise noticed by the scanner.
Jul 05, 2010 | 1997 Dodge Caravan
I cannot figure out how to attach football inflating needle to Topeak Joe blow sport?
Older model pumps screw in. Newer models get inserted and then you either push the lever down or pull it up to lock onto the threaded end of the needle
Sep 27, 2009 | Topeak Joe Blow Ace Floor Pump
I have a 2 barrel carb off a 283ci 1967 chev carter carb
no spring poss small wire from needle to float! the way it works is float is up needle close because float bowl full--when fluid or gas goes down valve opens lets fluel in.ck full pump disconnect line at carb crank over with guage should have apprx 7psi of press not less then 5psi carefull gas flameable
Aug 30, 2009 | Chevrolet Chevy Cars & Trucks
Temp guage runs in the red! 93 mark VIII 135K miles
has the water pump been changed recently? The water pump on a 4.6L 2v and 4.6L 4v look the same but are different
Apr 18, 2009 | 1993 Lincoln Mark VIII
Honda
sounds like fuel level indicator is sticking, remove fuel pump and clean fuel level indicator, or replace. hope this helps
Oct 18, 2008 | 1992 Honda Accord
97 Silhouette Fuel guage not working correctly
drop fuel tank. if guage moves all around its probably the fuel level sensor on fuel pump assembly in the fuel tank. If the guage stay's in one spot its the guage , replace instrument cluster assembly. you can take just the glass off the cluster and move the fuel guage needle and it will work (if stuck) but for how long? The wires to the guage come from the sending unit to the power train control module to the instrument cluster. pray its not in the wiring.
Sep 14, 2008 | 2000 Oldsmobile Silhouette
Topeak Joe Blow Ace Floor Pump Logo
125 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
numbers819
Level 1 Expert
dante
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
