Sometimes it not getting switched on when power is given to ups?????
    Scholar:
    New Friend:
  • 129 Answers
Hi Vikas,
Sometimes this happens because the batteries are exhausted in the UPS. If the batteries cannot hold out until the power comes back... the UPS will turn off completely. It will then need to be restarted manually. There are some UPS's that have an auto-restart feature but I don't think that applies in your case.
Reply or call if you have any more questions about this -- 800.260.2259
Posted on Nov 02, 2013
Have a Coleman air-condition no power in or outside I had the large capacitor replaced about 3 months ago because compressor failed to run.All breakers have been checked any ideas?
C'mon, get real!!!!!!!!!!!! If you have no power in or outside how can the breakers be any good? Pay your utility bill?
Outlet in wall good? Power cord ok? On/off switch checked?Thermostat?
Aug 18, 2017 | Coleman Heating & Cooling
I was given a coleman Powermate 400 watt inverter I hooked it up to a car battery and the fault light immediately started flashing I do not have a manual based off this being given to me.
I'm sure you can easily get a PDF manual on-line somewhere.
My guess is that sometimes these inverters will give an error if you do not have something plugged in creating an electrical draw
Mar 02, 2016 | Coleman Electrical Supplies
Why there is no Power in my Aoc L42H861. Power Light lights up but there is no power? When I turn it off the standby light blinks about 6 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 16, 2014 | Televison & Video
2004 Impala drivers side window will not go up
The problem may be in the driver switch.
The motor runs in both directions. So when the switch is centered, both wires are grounded. When the switch is moved to up one wire is given power and in the down position the other wire is given power.
If one wire is always hot and the switch is centered, the motor may be fried.
You can try applying fused power from the battery to one wire and grounding the other to see if the motor will move.
Feb 03, 2013 | 2004 Chevrolet Impala
I have a 1995 pontiac grand prix sometime it will start and sometimes it won't. i thought it was the starter solenoed so i bought a new starter but it is still doing it. when i turn the key everything...
Given the age of the car I'd check the neutral safety switch and the shifter linkage it could be causing the neutral safety switch to get a bad reading. After that I'd check the ignition switch itself. I don't remember if the '95 had a starter switch relay but you might check that too.
Jun 15, 2010 | 1995 Pontiac Grand Prix
Dash lights out
check the instrument panal fuse. if ok check and be sure if tail lights and etc are working.if they are working and still no panal lights, it maybe there is no power going through dimmer switch. see if power is going to switch. if not coming out of switch it is bad. the wheel where you dim the lights has a rheostat inside and it may have given out.Check your headlight switch. Sometimes the switch goes bad and the dash lights won't light. Replace the switch for the fix. if not the dimmer switch is bad.
May 20, 2010 | 2000 Chevrolet Malibu
It seems the off/on switch is broken
Sounds like a Hoover, which you had given the model number. But there are 2 or 3 screws to remove the handle, then there are 4 screws in the tool compartment, open the filter door, then the tool comp. should pull out, the switch part # is40309033.
If it is different then this pic, let me know:
Feb 19, 2008 | Vacuums
Garmin GPSMAP 60Cx Powerup Problem
I suddenly had the same problem. Here a page with the explanations : http://forums.motionbased.com/smf/index.php?topic=3814.0 I removed the cache back to clean power connectors, tighten the cache back to properly adjust the power connectors on the map. Now everything is working properly.
Oct 31, 2007 | Garmin GPSMAP 60Cx GPS Receiver
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
