Question about ASUS M2N68-AM SE2 Motherboard
M2N68-AM Plus cpu fan full speed
  • 323 Answers
SOURCE: it shows on startup
You might have a combination of several small problems. I would like to know whick processor you have installed. But Here is how to get started:
1) Open the case (after unplugging the PSU, not just turning it off). Use a wrist grounding strap or touch the bare metal on the case frequently.
2) Pull the jumper off the 1st two pins of the RTC. Place them on the 2nd two pins for about 10 seconds. Pull them back off and place them back on the 1st two.
Plug the PSU back up and turn on the computer, pressing delete button when the fans come on.
3) This will enter the set up. Check to see if the correct CPU information is listed now. If not, the bios is not old enought to recognize the CPU.
4) activate Asus Update. Go to the site and update your bios from the site. You will have to clear the bios again after the new bios is updated.
5) at that time the motherboard's bios should recognize the CPU. This happens frequently with Asus boards particularly where you have an AM2 board or AM2+ and you are installing a Phenom AMD PCU.
Let me know how this works. There are other things we can do. This is the only thing about Asus boards I dislike.
Sirwriter
Posted on Nov 14, 2009
darkpain
  • 316 Answers
SOURCE: cpu fan stop few second after starting pc
Hello,have you installed new motherboard or CPU?
Follow these steps again
1) Disconnect the power cord from the back of the computer & open up the case.
2) Wear an anti-static glove or at very least discharge your static by touching a metal surface or power supply
3) Disconnect the main 20pin ATX power connector from the motherboard & the square 4pin ATX2 power connector
4) Remove any PCI cards you have & disconnect ALL drive cabling from the MOTHERBOARD. Also disconnect any internal USB fly leads from the motherboard.
5) You should now have ONLY the cpu+heatsink/fan, memory & video card installed. Locate the round silver battery in the bottom right corner of the board. Just below it, you'll see a plastic jumper cap. This cap should be covering 2 pins (pins 1 + 2) with pin 3 bare. It will be marked JP1. Move the jumper to cover pins 2-3 instead. Leave in this position for about 30 seconds, then return the jumper to its original position (pins 1-2).
6) Reconnect the square 4pin ATX2 power connector & the main 20 pin ATX power connector. Make sure that the case speaker or buzzer is connected also.
7) Make sure the only external devices connected are the keyboard/mouse & monitor. Reconnect the power lead & power on the system
Let me know what happens
Posted on Feb 06, 2010
  • 11800 Answers
SOURCE: Does a M2N68-AM Plus (Asus motherboard) have to
Yes, it will work, just that the fan control will be missing and the fan will run at full speed constantly.
Posted on Jun 22, 2010
jecboys
  • 35 Answers
SOURCE: with asus m4a785-m motherboard and amd phenom x4
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Posted on Dec 17, 2010
  • 43 Answers
SOURCE: M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
Posted on Feb 12, 2011
M2N68-LA motherboard 12vdc for the cpu fan is only 4vDC.
first change u r smps if no diffrence problem is same then disconnect all chassis fan one by one and check voltage again.
Feb 05, 2013 | ASUS M2N68-LA Motherboard
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Power shut down shortly after bios loads
Check the processor and heatsink/fan. If there is a bad contact between the heatsink and the processor, or the fan fails to turn the BIOS will shut the system down to protect the CPU from overheating. I hope this helps.
Mar 02, 2012 | ASUS M2N68-AM PLUS Motherboard w/ AMD...
Feb 12, 2011 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
ASUS Motherboard M2N68-LA (False) "cpu fan has failed" If I press the F2 on the keyboard, bypass this failure and computer keep running well.
U'L LDAMAGE YOUR MOTHERBOARD AND THE CPU TURN IT OFF AND UNPLUG ALL CABLES OPEN THE CAS COVER AND CHECK THE CPU FA N IS MOVING OR NOT IF NOT THEN CLEAN THE FAN AND CHECK THE FAN CABLE IF IT STILL NOT MOVING CHANGE THE HEATSINK INCLUDIN THE FAN DA VN
Jun 13, 2010 | Intel D915GAG Socket 775 Motherboard -...
When i power on cpu fan start initially and then sop
try to change your fan proccesor or your power supply adapter for your CPU
Mar 12, 2010 | ASUS M2N68-AM SE2 Motherboard
Cpu fan stop few second after starting pc
Feb 06, 2010 | ASUS M2N68-AM SE2 Motherboard
It shows on startup ''a new cpu is inserted in your system'' with asus m2n68-am plus. its brand new.
Sirwriter
Nov 12, 2009 | ASUS M2N68-AM SE2 Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
ASUS M2N68-AM SE2 Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
