Question about Ovens
Whirlpool Saturn oven. Power outage now I can't reset clock as no manual found
SOURCE: oven elements will not heat
Just a follow up report on aborcass's solution to the oven problem.
Just took delivery of the suggested part, removed old thermister and installed new part, back to the breaker and apply some juice to the circuit.
Turned on oven....BINGO!!!!!
Oven now is as hot as the wife would like it!!
Well done and well earned FixYa (already awarded)!!
Many thanks again
Steve, aka kf6wax
Posted on Feb 27, 2008
MARCLAVORIS
  • 110 Answers
SOURCE: Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Posted on Apr 03, 2008
SOURCE: power cut and now cant reset the clock
We flipped off the designated breaker to the oven and turned it on again. We were then able to reset the clock. This has happened to us several times.
Posted on Nov 17, 2008
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
What does pf on digital display mean? Oven will not work
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
Dec 07, 2009 | Whirlpool Ovens
Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven elements will not heat
theres a thermostat on the back wall that problaby blew out as a result of surge,its wired in line with both bake andbroil element
Feb 24, 2008 | Whirlpool GBS277PDS Electric Single Oven
Aug 09, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
