Question about Makita Drills
HI, I have a Makita BPH452, it rarely has been used.. so the last time I used it, I was drilling through wood and I may have it metal or something that caused the drill to spark, I finished the job, everything was okay, the next day I charged the battery and the dril made a `tick`when i push the button, tried reverse `tick`and after a few times the tick went away and now the drill doesnt move at all, even when i try to force it by hand... i tried a couple other batteries so its not the battery... thanks
stug_57u
  • 99 Answers
SOURCE: bosch psb 600 drill will not reverse
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
Posted on Oct 26, 2008
rowdy45176
  • 2176 Answers
SOURCE: Hammer switch jammed on Makita HP1621K/2 Percussion Drill 2
I looked at Makitausa.com website and it appears that you might be correct. there are 4 parts to this assembly and one of the problems might be the cam holder position #17. I would suggest that you go to their site and take a look at how the parts are supposed to be. I used the model number in the large header so this might not be the exact one that you have. Let me know and I will try and help further.
Posted on Feb 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have the black and decker hammer drill model
look at the back of the brush holder for a tab that the forward/reverse lever locks into, it might be broken not allowing it to shift.
Posted on Mar 03, 2009
  • 3 Answers
SOURCE: drill keeps on stopping and won't restart
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Posted on Mar 12, 2009
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
Makita 6723dw
This is a light weight cordless screw driver, so it all depends on what material you are trying to drill. It will probably drill small holes in wood and possibly in softer metals. It is made for light duty work, so again, it depends on what the material is, so if you are reffering to wall board such plaster board or sheet rock, it will drill smaller diameter holes.
Feb 04, 2014 | Makita Drills
My makita batteries nolonger charge
Lithium batteries do have a life span determined by how many times the battery is discharged and recharged and how hard it is worked on the tool. Batteries get hot while charging and discharging and heat is what ages batteries. Lithium batteries, depending on usage, will last from one to three years. I've seen some last five years but that's rare. They also have numerous cells and a circuit board that can go bad and kill the battery. Chargers are designed to check the battery's condition and won't charge a battery if it detects something wrong. If your battery is under one year old, it's covered by the warranty. If it's over, you'll have to buy a new battery.
Mar 03, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I do not understand about torque on my new makita 18v lithium-ion battery drill. When I use it through drywall then into wood or straight wood into wood it seems to stall when I am almost done. Is this to...
Hi Kathy,
Welcome to fixya!
You adjust the torque by increasing the setting on the dial behind the chuck. It will feel to you as if you increased the power when you drill.
Don't set it higher than you need it. Just increase the setting until you're happy with the way it's working.
Good luck
Please place a vote and keep me working here...
Thanks,
Handie Andie
Aug 14, 2011 | Makita Garden
Removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Feb 19, 2010 | Makita 6408K 3/8" Variable Speed,...
Clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
How do i re-assemble a makita 18v cordless drill
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Dec 21, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Makita 6337D cordless drill problem
It is possible that the batteries are no longer good. They may need to be changed. These batteries do reach a stage where they no longer hold charge.
On rare occasions I have seen the gear box jam or the motor bearings go defective.
Jerry G.
Apr 01, 2008 | Kitchen Appliances - Others
Drills Logo
60 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
