Question about Samsung Washing Machines
WF70F5E2W4W wont spin wash pauses half way through wash
2 Suggested Answers
nanbuenbrazo
  • 553 Answers
SOURCE: wont spin
just try to open the back or the bottom of the of your washing machine, see if you can find the belt attached to the motor, see if it loose or mis-alligne, have it fix or change the belt if necessary
Posted on Nov 01, 2009
Zanussi washing machine pause button flashing machine wont work iz141s
Disconnecting the wires from the main PCB helped resolve half the problem, but the machine still does not rinse and spin. Unless programmed manually. Still, that's easily done at the end of a wash cycle. Is liveble.
Jul 24, 2012 | Zanussi ZWF1440 Front Load Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Wont spin
Nov 01, 2009 | Kenmore Washing Machines
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
The washing wont spin or drain i replaced the lid swicth didnt work
Set the washer for spin and turn it on.
If it does not spin, open then close the lid and see if it spins.
If so set the timer for regular wash. When the timer gets to the final spin it should PAUSE a few seconds. The transmission will lock in, then it should spin.
If you do not get the PAUSE in the timer at the beginning of the spin cycle the timer is bad.
If you do get the Pause and it does not spin the transmission is bad.
Mar 18, 2009 | Whirlpool Washing Machines
Washer kenmore series 80 after wash or rense cycle wont start to spin when dumping water. Sears repair man says that is normal and I say it used to spin. what is the problem?
There is no problem, unless the drum doesn't spin at all.
In a wash or rinse cycle there is a neutral drain just before the spin. During the neutral drain, the drum does not spin. If you open the lid or pause the timer during the neutral drain, the motor will stop (same as the short pause just before the actual spin) and the "kicker" in the transmission will disengage the brake. At this point the drum will start to spin. The neutral drain prevents wear and tear to the transmission since the drum will be very heavy while it's full of water and wet clothes.
If it doesn't spin at all, you may have a problem with the motor coupling, the brake/clutch assembly or the transmission.
Hope this helps to clarify things.
Mar 02, 2009 | Washing Machines
Ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Jun 03, 2008 | Washing Machines
Washing machine.Fisher and Paykell Kelvinator
check the lid switch under the lower board they rust and the fault is normally not starting,or the display board can rust inside near the start/pause button if so try and unsolder a button you dont use and replace the start button.
Mar 03, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
