I have a wd-10260np model. the door clip lock was worn out already. i cannot open the door. i need to open it with force. so please tell me where can i buy this door clip lock????
  • 24 Answers
Try bending it slightly with a screw driver and a needle nose pliers. Worked for me.
Posted on Apr 24, 2009
Getting door open
Can you remove the trim from around the interior handle? If so do that and actuate the rod manually.
Jun 02, 2016 | Cars & Trucks
The latch on my drivers side door is stuck in the closed position. How can I get it to open so I can get my door to close. It can't close at all right now.
Does the door latch have a child safety lock feature? Check to make sure it wasn't accidentally activated, preventing the latch from opening.
Feb 20, 2015 | 1990 Chevrolet Lumina
Broken door locks
Then you'll be needing to remove the inside door panel. There should be a clip on the lock mechanism and a rod attached to it. What I'd do is go down to a u-pull it lot and find a similar model and remove the door panel and see what you're up against. Then you can decide if you want to get into it yourself or have it done by a mechanic or a locksmith, whichever is cheaper. Goog luck.
Mar 29, 2014 | 1996 Toyota Hilux
We have a Samsung front loader. Model # WF328AAIWIXAA. We started the machine to do a load, and later we were going to transfer the clothes to the dryer. It appears to not be getting power. We cant open...
Is the display (User interface) is lighting up and on. That means you are getting power.
If display on and cycle stopping at mid cycle and cannot open door.
If the machine water level sensor detects sufficient water in the machine it will tell the control board not to release the door.
Is there is water in the machine. May be your drain pump is clogged. Does it give a error code on display.
Don't force open the door. You will break the lock and you will need $ 200/= parts and labor to change the door lock
Call a local service guy
Oct 25, 2017 | Samsung WF337AAL Front Load Washer
My door wont open from the inside but will open from the outside
This sounds like it could be one of a couple of things. The rods which attach the door handles to the lock assembly are held in place by plastic clips, these clips break and the rods fall out. You will need to open the door, remove the inner trims and check. If it has, replace the rod back into its slot and put a new clip on it. It may be that someone has tried to force the doors with a slim jim. This can result in the rods being bent or pulled off the lock assembly and can be fixed as above. If this is a rear door, check the child proof setting in case someone has turned it to the safe position. This is located around the lock assembly itself and can only be accessed when the door is open, look on the edge of the door next to the lock for a very small lever and swap it to the other position, then try the door from the inside..
Mar 16, 2010 | 1999 Toyota Camry
The driver side door will not lock and is stuck open can not even lock with the key
You need to take door trim panel off and see whats going on Probably needs lube or a linkage come off Door panel got screws in armrest on door latch rest just clips on but take care popping clips then lift it up
Oct 23, 2009 | 1998 Nissan Pathfinder
I have a 1998 jeep cherokee and can not open rear (trunk) door It feels like the key is unlocking and locking, but raising the door handle will not let me open the door?????
spray a light lubricating oil into the locking or catch mechanism, you will need to have the door opened already though. WD 40 should work well. I have a 98 cherokee limited and had a similar problem when I purchased it used. It would lock and unlock, but it wouldn't open. To first open it I had to push the handle down while I pulled the latch up.
Aug 21, 2009 | 1998 Jeep Cherokee
Have a 86 Olds 98 with power door locks. Driver's side door will not unlock. Other doors are fine. Can't unlock it manually with either the switch or the key. Was getting difficult to unlock with the...
Most likely the solenoid in the driver's door has failed and will have to be relaced. You can check this by removing the door panel to gain access to the soeoid, remove the rod (be careful with the plastic clips), and try the key. If it opens and closes the lock with no resistance, it is the solenoid. Replace it and your done. I hope this helps and good luck.
Jul 11, 2009 | 1986 Oldsmobile Ninety Eight
Driver door wont lock, need help
Probably just needs a good shot of WD 40 or any other lubricant. Spray the catch on the door, and trip it with a screwdriver a few times. If that doesn't work, it may need adjusting or be worn out.
Jun 28, 2009 | 1996 Volkswagen Jetta
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
