Hi there I was using my Nash washing machine (NWM-65FL) and suddenly I heard a very strong voice and start shaking very hard and even machine jumped forward I turned it off and took out all the clothes Just I want to know do you have any service center in Dubai to call them for repair otherwise how you can help me to fix it Thanks
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine MOdel 22622100
If the sound is a grinding noise, this is usually a symptom of a gear case (transmission) going bad. However, it could also indicate a motor coupling that's starting to fail. If you look under the washer check for any drips or puddles of oil. If you find any, the transmission has begun leaking and needs to be replaced. If you find a black powdery looking substance, this is an indication of a motor coupling that is failing. I hope this may help you. Let me know what you find.
Posted on Jul 10, 2007
watugot
  • 290 Answers
SOURCE: Calypso Washing Machine
There are two places a coin could be that will cause a noise. Either in the basket under the nutator or in the pump. If you hear the noise after the basket stops from the spin, look under the nutator, if you hear it during the cycle, check the pump. If you only hear the noise during the agitation, not the spin cycle, you may have a u-joint going out.
Posted on Oct 03, 2007
SOURCE: My Washing machine stains clothes;
I've had this problem for many months now.  Even when it ruined my favorite tops & jeans, I couldn't get myself to let go of them... Good thing though because I have found a solution!  Make a paste using cream of tartar and hydrogen peroxide.  Generously spread the paste over the stains and let sit for about 5 minutes.  Boil enough water to fully immerse the stained garment in.  While waiting for the water to boil, figure out a way to wrap/roll the garment so that the paste doesn't come off when put into the water.  You want the paste to melt onto the stain while in the hot water.  After wrapping/rolling the garment, secure it with string or thread (anything that won't melt) that doesn't have color, just in case it bleeds.  After the water has come to a full boil, immerse the garment into the hot water and let it soak.  After about 15 minutes, remove the garment from the water.  The water should still be very hot, so I use cooking tongs to get it out.  Let the garment cool down to room temperature while still rolled up.  After it has fully cooled, unwrap the garment.  There should be very little or none of the paste left on the stain.  If there is still a great deal of paste, you may want to soak it again until the paste melts a bit more.  Once the paste is gone, rinse of the garment and it should be clean & stain free.  :o)
Posted on May 03, 2009
SOURCE: Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Posted on Jun 04, 2009
SOURCE: Samsung WA71N2, plugged to 220V should be 110V only
chang the board! servise center will charge probably 400sr
Posted on Feb 03, 2010
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
I have samsung wf9904cwn washing machine. After washing the door closed and could not open.Can any one help.
My samsung wf9904cwn stop suddenly and re start suddenly and shake with noisy sound how can I solve this problem or to reset to the defualt factory settings?
Sep 25, 2014 | Washing Machines
Whirlpool washing machine imperial series My washing machine is shaking hard when it spin dry
Well if it's a new machine then it look normal or let me know if you note some changes in natural function, most of this series washing machines shakes hard when they are on dry spinning. This series is mostly known for dryer's.
Regards
Nov 06, 2011 | Washing Machines
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
My front loader shakes when in the spin cycle. It shakes a lot! I am not overloading the machine, and the floor is level help?
Hi from retired Englishman in SW France @20:54 Sat evening 'cos there's nothing on TV!!
Please don't take offence BUT- the floor might be absolutely level BUT the feet on the washer might not be adjusted absolutely perfectly- honestly!
Always shows up most during spinning of course.
I would strongly suggest that you, or a helper, with the machine not working, push STRONGLY at one of the front corners to see if the washer rocks even the tinyest bit. If not one corner then the other.
The back feet do not need to be adjusted, just the one under whichever corner rocks.
It needs adjusting (downwards of course) until it is tight on the floor, really tight but without lifting the machine at that corner. This will ensure stability for starters.
If the machine stills rocks it is possible, although a bit unlikely, that one of the shock absorbers which assist in the suspension of the drum might be malfunctioning. It would need chanmging of course but do check the feet first.
Hope this does cure your problem.
John C
Jan 29, 2011 | Frigidaire Affinity ATF7000E Front Load...
Starter suddenly stopped working. Loud bang when
It's most likely a timing problem, you may try too adjust it yourself; Loosen set screw on distributor and get a timing light. there also a chance it jumped a timing gear when you heard the loud bang..
Jul 11, 2010 | 1994 Chevrolet Corvette
Hi, Have you heard of problems with the new washing machines that spin so hard they damage floors?
I have not heard of the machine damaging floors. the new front loading machines do spin at a high rate of speed. It is so fast that if it is not on a solid floor it will shake the floor. I have been in homes that have a front loarder on the second floor and it literally shakes the whole house. This is why this machine should be only on concrete floors.
Dec 23, 2008 | Kenmore 24032\24036 Top Load Washer
Mar 17, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
