Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Crashed Widows XP on my sahara laptop
I tried to upgrade Winxp 2003 to laptop froze during the process. I switched the laptop off-then back on. Windows are not loading now.There'es this message." corrupt or missing system file \windows\system32\config\system Insert original windows CD to retrieve this file.Press "r" at the first screen. The problem is the laptop came pre-loaded with Win XP and I only have the original Win Vista upgrade cd.I tried the "r"retrieval,but the Vista upgrade cd is probably not a Dos compatable cd. i tried restarting-pressed F8-most recent settings that worked,also safe mode,basically everything faild Please advise thanks Thomas
  • Anonymous Mar 14, 2014
    My HP laptop with Win xp tries to boot but then quits. Sometimes if I hit the escape button repeatedly it will boot, but mostly not.
If you have this problem but dont want to format the drive (HardDisk) Set the device boot priority so that the cd rom is first to boot usualy press the f1 or f2 key rapidly as soon as you fire up the system ive also known it to be f8 on a safe mode page after you have figured it out insert the windows software cd and restart the system it will instruct you to press any key to boot from cd it might be different on you pc i know on dell it boots otomaticly i run a compaq and have to press any key once the cd boots and you get to the selection screen there should be a choice to set up windows (Version)(example xp vista) or (R-repair) you need repair so press r and hit enter after a few soconds a screen should appear (Black) it will have a bunch of writing press the number of the operating system you are trying to repaire exm.1234 and hit enter then it will ask your administrater password note if the pasword you use to log onto windows doesent work just hit enter with the section blank after a few seconds it should say somthing like C:/ enter CHKDSK /R and hit enter this will take a while but after about an hour it will finish and instruct you to restart remove the cd and restart your system what you have just done was rewrote all the start up files needed to run your copy of windows if you copy was already activated you do not need to redo this step just start the system and enjoy if this does not work post a new message and give a little detail on why and i will instruct you on a new method thanx
Posted on Oct 01, 2007
  • 2,961 Answers
It sounds as if you the system as you say has failed, you can use a friends copy of XP but use your product key number on the underside of your laptop. Secondly, the vista CD may be an upgrade cd but you will probably find that it will do a complete install as they are normally the same cd, just set your cd drive as first boot device and then run the cd,select new installation and not upgrade; i have an upgrade Vista cd but installed a full operating system on another partition, therefore it wasnt an upgrade but it still worked.
Posted on Sep 25, 2007
Laptop wont load into windows
Use a windows recovery disk. If the laptop is running Win7 the process will be automatic (when you instruct it that you want to carry out a repair). If it's WinXP or Vista it will be a bit more involved.
Jun 21, 2012 | Computers & Internet
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see:
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
Cannot connect my MT6225 china phone to my laptop thro the USB. what can i do?
hello, u may have to download the proper drivers plus data manager software from the manufacturers homepage,
they have to fit vista!
if there are just ones for winxp or lower win/versions available, either try connecting phone to a winxp/interent-pc and go through driver-install and so on
or think about downgrading your system to win-xp professional!
win vista is fine but not as reliable as winxp/pro!
good luck
Aug 07, 2009 | Microsoft Windows? Vista Home Premium...
My iriver froze during the firmware upgrade process.
the firmware before must of corrupted and has made unreadable and undeletable an thats why it has froze during the firmware upgrade process
hope this helps
i would reformat it
Jan 23, 2009 | iRiver E100 Digital Media Player
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update:
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Failure to load windows
If you can try a different hard drive. And make sure the format of the hard drive that's installed doesn't freeze or doesn't complete.
Those are just the first things that popped into my mind,
I'm sure other's will have more suggestions.
Good luck.
Feb 26, 2008 | Toshiba Satellite A65-S126 Notebook
Unable to connect to anything
what process did you do when upgrading windows Vista? If your going to upgrade with Windows Vista, Old version of windows will rename to windows.old so you can't access this old version because windows vista will take the priority, so all your program will disappear. You need to purchase another software for microsoft office.I hope it will enlightened your mind.anyway there are some process of making it possible for dual boot.if you are in need to experience windows vista at the same time windows xp.
Nov 26, 2007 | Acer Aspire 3610 Notebook
Dead laptop
Nothing? No lights, no sounds? Check the power supply and battery. Otherwise try to re-install windows over the top of your existing installation.
Sep 21, 2007 | Toshiba Satellite A60 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
131 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
