Question about Skagen 233LGSC Wrist Watch
Skagen 817ssxc watch battery - Skagen 233LGSC Wrist Watch
Noggin
  • 944 Answers
SOURCE: Skagen 433LSLB Watch Battery
If you take the watch to any jeweller they will be able to identify the battery type required - also they should be able to replace the seals, which are always worth replacing when a battery goes. Here is the link for contact with Skagen if you need it; http://www.skagen.com/service.asp Hope this helps :)
Posted on Mar 25, 2007
SOURCE: Batterry replacement for Skagen-355LSSM
Without a Case Closing Plier ($15 to $20) or a Case Closing Press ($15 to $50) you will not easily be able to get the back to snap back in - see WikiAnswers
Posted on Aug 21, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 103 Answers
SOURCE: replacement battery for Skagen 430SSXD watch
send your watch into skagen since you have a lifetime warranty you do not want to breech that. plus they reseal your watch and other watch repair places cant.
http://www.skagen.com/service/home.fx
Posted on Aug 04, 2010
  • 22 Answers
SOURCE: Hi, My wife skagen watch
I have had to replace more glasses in this watch than any other brand over the last two years - It is most definitely a design flaw. The truth is though that you will not need a genuine skagen part. Your local watch repair shop will be able to use a standard 1mm thick domed Mineral Glass manufactured by Sternkreuz for example. It should be fitted by a qualified watch repairer, but you should not need to send it to Skagen. Good luck
Posted on Sep 20, 2010
Who is qualified to replace battery in Skagen watch in Edinburgh Scotland
Go to any jeweller of department store. They carry all the batteries, and the tools to remove the back. Costs about £10.
T. Paterson Jeweller ' Skagen watches ' Perth ' Scotland
www.patersonjewellers.co.uk/skagen-watches-perth.html
  1. Cached
  2. Similar
Sleek, minimalist Scandinavian design defines the Skagen watch brand. A distinctive range of watches for those wanting something a little different.
Skagen watch Google Search
Jun 07, 2017 | Skagen Watches
Replacement battery for Skagen 430SSXD watch
Mar 13, 2010 | Skagen 430SSXD Wrist Watch
Skagen 380ltrm batery replacement
No need to do this yourself; many sellers of watch batteries do this at no charge. But actually it's not that difficult if it's anything like my Skagen it's just like other watches I've had - take the back off, switch batteries, close it up.
Nov 16, 2009 | Skagen 433LSLB Wrist Watch
433LSLB stops working, sometimes overnight,
send it into skagen it has a lifetime warranty
http://www.skagen.com/service/orderWatchBandParts.fx
Aug 05, 2009 | Skagen 433LSLB Wrist Watch
Watch battery and manual for Skagen 271sgxd
try sending it to skagen they can fix your watch and you will still be covered under there lifetime warranty!
http://www.skagen.com/service/watchWarranty.fx
p.s. the manuals are all on this site as well!! thanks!
Jul 03, 2009 | Skagen Ladies - DEMI CRYSTALS LINK WATCH...
What battery does the skagen 233ltmb require?
i would send your watch to skagen and let them replace it for a very low price. plus then your warranty will not be voided and you wont risk someone damaging such a great watch.
May 03, 2009 | Skagen 233LTMB Wrist Watch
I dont know what battery goes into a Skagen 233LSS
send it to skagen for $15 they will look it over and replace the battery without voiding the lifetime warranty
Feb 01, 2009 | Skagen 105LTX Wrist Watch
Broken Skagen
try sending it into skagen you have a lifetime warranty
Sep 04, 2008 | Skagen 271SSSMPD Wrist Watch
Mar 10, 2007 | Skagen 433LSLB Wrist Watch
Skagen 233LGSC Wrist Watch Logo
42 people viewed this question
Top Skagen Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
