Question about Royal 112MX Shredder
Royal 112 wont start - Royal 112MX Shredder
Is it possible to unjam this shredder. It was allowed to get too full and I started eating it's own shredding . I have pulled all of the paper out that I can - but it still won't go.
If you have cleared all jammed paper out of the unit but its dead and wont run then its likely you have blown the PCB inside...replacement parts you can get from Royal at 1-800-524-0799.
Oct 16, 2010 | Royal 10X Shredder
I have a royal alpha 9500 ml cash register and also a royal PS700-USB hand held barcode scanner. Everything worked great yesterday getting my barcodes in the cash and stuff, but I unplug it by accident...
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
Aug 11, 2010 | Royal PS700-USB Handheld Barcode Scanner
Royal vf700 paper shredder wont turn on
If it wont run forward or backwards then probably the pcb inside is fried...call Royal at 1-800-524-0799 for parts assistance.
Jan 05, 2010 | Royal VF700 Cross-Cut Shredder
Royal Orca 9512x shredder will not run. I have checked the fuse and it is good. Cleared a paper jam and still wont run forward or reverse.
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Sep 15, 2009 | Royal 15MX Shredder
Tascam model 112
The 112 unit uses a cam operated transport- it may need a new 6.5" belt and some head base lubrication as well as the feedback pot spray cleaned. I do them all the time.
Jul 26, 2017 | Tascam 122MKIII Single Dual Cassette Deck
Royal 112MX Shredder Logo
47 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
