Question about Briggs & Stratton Garden
What spark plugs for 11 hp generator motor? - Briggs & Stratton Garden
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 23 Answers
JL19LM Champion brand
Posted on Aug 05, 2015
2 Suggested Answers
huffman49
  • 235 Answers
SOURCE: Have an 11 hp B&S rider getting no spark to plug.
1ft remove the shroud that covers the flywheel and find the magnets either they will be on the outside rim or if you can't find them on the outside there are on the inside(then you will have to remove the flywheel) after locating the magnets (use a socket any size)t will stick to the magnets take some sand paper and rub the rust off, just enough to remove the rust,wipe with a clean rag then reinstall the shroud and check for spark...good luck
Posted on Apr 08, 2010
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
Oct 01, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
What spark plug does a mc collough 5700 11 hp generator take?
The manuacturers part number is: 030506Q01F910
Manual:
http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_FG6000MK-7096FG6024_966991401.pdf
Is there a brand.... on your current spark plug?
Most generators will do just fine with an NGK BPR5ES spark plug in most any environment.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
I need a spark plug for a 5700 watt 11 hp generator, which one do I need?
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Kelly
Feb 19, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
Generator will not start
If your generator does not start and you have followed manufacturer's directions that came with your owner's manual purchase, there may be a problem with the motor, the points or the spark plug. Try removing the spark plug and checking the gap, then check the start process again after putting it back in. If still no ignition, check the points to make sure they are not burnt. If they appear all right, check to see if you have good compression. If there is not good compression, the rings would need to be changed. If this fails, and there is sufficient gas, it might mean that your motor is inoperable, due to wear and tear of everyday use.
Dec 15, 2010 | Briggs & Stratton Briggs Stratton 30208...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
