Question about Garden
Toro weedwacker fuel line diagram model # 51972
SOURCE: I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf, I had to buy fuel lines last week. I called the local sears parts store, and gave them the model number. They had a rather generic bag with the correct diameter lines. Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off. Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb? Thanx.
Posted on Jun 22, 2009
rycgl
  • 1545 Answers
SOURCE: replace fuel lines,craftsman weedwacker,
Fuel filter in tank with line going directly to the fuel pump side of the carburetor This is the end of the carb with a solid cover. . This line should have length in it inside the tank where it can flop around and stay on the bottom to collect fuel. The other line in the tank should have one of the little connectors on it and can be right up to where the hole in the tank is to hold it there.. This line should connect to purge/primer bulb on the longer outlet nipple. Another fuel line should run from the metering chamber side of the carb (the end with the hole in the cover) to the purge/primer bulb with the shorter outlet nipple.
The purge bulb "pulls" fresh fuel out of the tank via a vacuum created after depressing the bulb and the fresh fuel flows completely thru the carb and any air or old fuel ahead of it are drawn to the purge bulb which then "pushes" this mixture back to the fuel tank.
Posted on Jul 11, 2010
rycgl
  • 1545 Answers
SOURCE: craftsman 21cc weedwacker, need fuel line diagram
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Aug 20, 2010
Testimonial: "this was very helpful and i thank you very much."
  • 19 Answers
SOURCE: replace fuel lines on weedwacker
You should be able to find a diagram for your model here - http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-316798221/0247/1503820?pathTaken.
Posted on Dec 13, 2010
  • 316 Answers
SOURCE: I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Posted on Feb 21, 2012
Need wiring diagram for a Toro Riding Mower Model 74413,serial no. 250000194
go to toro web site enter model # and should be able to get diagram,if not go to mower repair web sites they should be able to provide diagrams.
Jun 11, 2015 | Toro Garden
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
Jan 18, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
Jan 18, 2012 | Garden
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug....
that is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Aug 25, 2011 | Toro& Electric String Trimmer
I took apart the handle for my Toro Trimmer Model number 51972 and a spring fell out and I'm not sure where/how it goes back into the handle. I took it apart because the trimer runs but the spool does not...
Hello, Hopefully the exploded parts list can help you out... I've done the reassemble of a trimmer handle once and explaining it can get dicey. The only suggestion that helped me was to have scotch tape handy to act as a third hand when holding small items between two other parts. You don't actually wrap the item, just place it on a small piece of tape - when the item is in position the tape removes easily. Your diagram link is the top one. Good Luck!
http://www.poulan.com/node7925.aspx
Aug 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Trying to find a owners manual for a Toro grass trimmer model 51972
you can get it here: https://lookup3.toro.com/request/request.cfm
print for free or purchase copy
Sep 13, 2009 | Garden
Got a homelite ut 15039a (weedwacker with blade st 185)
You have the rong fuel tank for that model.Thats the return pipe its comming from so you can drill a hole if youwant but make sure its sealed properly.
Jul 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
49 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
