Question about Panasonic KX-FL611 Plain Paper Laser Fax
Problem on fax printing
My fax machine when printing showing two blank line vertically i have tried cleaning rollers and othe tirelod but still leaving white line which means other image not visible some time more white line appeared. so i dont know what should i do inoder to get clear image
    Problem Solver:
  • 9 Answers
Try to clean the SCANNER Unit.
Posted on Dec 30, 2007
  • 54 Answers
The problem is with drum unit there is charged crona grid clean it properly
Posted on Mar 03, 2010
We have fax kx-fl612cx so when we reseve a fax we rev tow sheet
Posted on Oct 20, 2009
  • 31 Answers
Try to clean the scanning unit.
it can be found to where your original is being inserted. just follow the path to where the original goes out.
it is a LONG GLASS. Clean it with alcohol and cotton or clean rugs.
Posted on Mar 11, 2008
I have a blank line running down the left side of all my faxes and copies. I have changed the toner and installed a new drum. Still having the problem.
You most likely have toner on the roller, which should be just above or below the drum, clean this by spraying some window cleaner on a paper towel, or lintless rag, and rubbing the roller clean, make sure to get all foreign particles of roller before closing and trying to print.
Oct 14, 2010 | Brother IntelliFax-2820 Laser Fax
Vertical blank strip
clean the roller and the cartridge head with alchol.
Jul 18, 2008 | Canon FaxPhone L75 Plain Paper Laser
Fax will not print test page comes out blank
Try another cartrige or clean the contact points of your print head.
Jul 29, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Muratec MFX- 1430 Printer
first of all, you can change the toner cartridge at any time. the roller below is probably the transfer roller, which can be cleaned. you may also want to consider that the drum cartridge could be the culprit.
since this is a multi function machine, make sure that the lines are not showing up when you print, or receive a fax. if the lines ONLY show when you copy, then clean the small **** glass under the document feeder, that should be the source.
Apr 01, 2009 | Muratec MFX-1430 Copier
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Vertical lines
1st print a report, can you see the lines? Then either the drum is faulty or the laser scanner is. If the lines are not present when printing a report, make a copy and see then if the lines appear. If so, the scanner is faulty. Try cleaning the glass with glass cleaner. However, blank lines mean that bits are missing from the scanner itself and the scanner will need to be replaced.
Feb 27, 2008 | Brother IntelliFax-2820 Laser Fax
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Panasonic KX-FL611 Plain Paper Laser Fax Logo
202 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
