Question about Bright Starts Baby Gear
I don't know how to reattach the padded seat in the Around we go activity center.
How do I reinstall ear pad on headphones?
Some headphone earpads are grooved to fit over a flange in which case 'shoving it around' may be the best approach. Other types may require application of a bit of glue.
Jan 15, 2016 | Audio Players & Recorders
How to activate ant theft system on Buick regal
Best antitheft is a padlock and chain from the seat to the steering wheel ,visable and effective ,do not mess around with the factory system ,do not a viper piece of junk or anything ,if i want to steal a car from the side of the road with some of my fancy computer thing i plug into the OBDII and use a slide hammer on the lock and in under a minute i have the vehicle started ,but if you think i walking around with a metre long set of bolt cutters?'
Nov 16, 2013 | Buick Regal Cars & Trucks
How do I convert a Nautilus 3 in 1 carseat to the toddler position
Turn around fold bar under sit in seat facing forward and reattach all anchor points again. to change belt posiotion look on back at belts should have a clip holding the 2 belts , take off thread through a higher position and reattach and adjust. hope this helps
Nov 18, 2011 | Graco Nautilus 3-in 1 Car Seat
Have a Minoura Bike-fellow given by a friend. No manual and don't know how to put the bike on it. Can anyone help please?
The down tube of the bike goes into the orange padded grips. The longer black hook goes around the seat tube.
Jun 29, 2011 | Cycling
How do you remove the cover and belts on an evenflo car seat with this number on the side 25801158?
Turn the booster seat around to the back and locate the metal splitter plate that the harness is attached to. Remove both harness straps from the splitter plate. Locate the TensionRight knob located on each side of the seat in the front by the baby’s foot area. Turn the TensionRight knob to the back as far as it will go to take up the slack on the splitter plate strap. Pull both harness straps through the seat back to the front of the seat. Remove the harness strap from both sides of the chest clip and from the buckle tongues. NOTE: Please leave the buckle tongues locked into the **** strap for storage. Remove the harness strap from the seat. NOTE: Reattach the chest clip to the harness strap so they don’t get lost. Turn the booster seat upside down and locate the metal harness anchor. Turn the metal anchor sideways and push it through the slot to the front of the seat.
Sep 08, 2010 | Evenflo Generations
Reattach seat to Evenflo Exersaucer
Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
Feb 07, 2010 | Evenflo Baby Gear
2003 Volkswagen Passat Center Rear Belt Locked
The fix is:
  • remove the seat bench,
  • unscrew the bolt attaching the seat belt to the body,
  • return the seat back to its upright position and make sure it latches
  • reattach the seat belt
  • replace the seat bench
To prevent this from happening again:
  • Leave the seat belt latch in its receiver when not in use.
Aug 09, 2009 | 2001 Volkswagen Passat
Rear seat not secure...slides around
Sorry to here that, not sure why someone would remove the seat.
There are (2) bolts that hold the seat cusion in place. One located on either side of the seat cushion about one foot in from the outside edge of the cushion on the bottom front edge.
If you lift the rear seat cushion up and look on the bottom of the cushion, you will notice a metal tab with a hole in it, both right and left sides.
On the floor pan there should be 2 metal tabs with nuts attached on either side to line up with the tabs on the seat cushion. You will need (2) 13mm headed bolts that are 2.5 inches long each.
They are not very easy to install.
Good luck, let me know.
Regards,
Mar 29, 2009 | 2003 Pontiac Grand Am
I need to know how to put the seat in an Evenflo Exersaucer Deluxe because we received it that someone didn't need it anymore. Its an older on from 95. Please can someone help me because my granddaughter...
https://plweb.evenflo.com/faq_detail.aspx?faqid=3934
Question: How do I put the seat pad on the Exersaucer? spacer.gif Answer: 1.Line up the red diamond on the seat pad warning label with the triangle on the back of the seat ring. 2.Fit the elastic loops through the quarter inch gap between the seat ring and rotating rings and hook the elastic loops over the prongs on the bottom of the rotating ring. 3.The plastic tabs on the seat pad are only for reinforcement and don't hook to anything, but should be threaded between the 2 plastic rings. If you still need further assistance please refer to the instruction sheet or call the Evenflo ParentLink Consumer Resource Center at (800) 233-5921 or (937)773-3971 for further information.
Mar 25, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
ACTIVATING DRIVERS " SEAT HEATER" SWITCH BLOWS FUSE
This would Definately be a Short And, Yes you Can just replace the Pad. Could just be that the Wiring is in a Bind and needs to be Moved around. Seeing that it only has 5000 K on it, It should still be Under the Factory Warranty and they should repair this Free of Charge.
Jan 02, 2009 | Hyundai Veracruz Cars & Trucks
Baby Gear Logo
85 people viewed this question
Top Bright Starts Baby Gear Experts
Dorel UK
Dorel UK
Are you a Bright Starts Baby Gear Expert? Answer questions, earn points and help others
