Question about LG WFT1071TP Top Load Washer
I have a LG WF-764STP which wont spin the clothes or drain properly after. Where is the filter?
  • 686 Answers
THE NUMBERS YOU HAVE PSOTED YEILD RESULTS FOR ALL TYPES OF APPLIANCES AND IS DIFFICULT TO HELP. SEE AND POST THE CORRECT MODEL NUMBER OF YOUR WASHER FOR FURTHER ASSISTANCE.THANK YOU
Posted on Apr 24, 2009
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
Hi there ! I have a LG Top loader WF-T7030TP that wash the clothes but do not want to rinse,spin and drain the water.
you have blockage in your drain in the machine-possibly something stuck in the drain pump like a sock or a paper clip-tear it down-have a couple of old towels handy for the mess-cheers Denny
Oct 21, 2013 | LG WM Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
I have the LG Fuzzy Logic WF T1022TP 13Kg top loading washing maschine. Everything starts off well, but when its reaches the spin cycle, it freezes and wont let the water drain. It also happens that the it...
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 25, 2011 | Washing Machines
LG WF-17014PP will not rinse or spin
check the pump, there is probably a small piece of cloth in there like a sock. This happens all the time. When the motor cant turn the other direction, the locking mechanism to the gears wont engage to do the spin cycle. Turn the wsher on its side, the pump should be easy to remove, they are fasten by two long clips. get back with me if this solves the problem
Jul 01, 2009 | LG WFT1071TP Top Load Washer
LG WF-764STP
Washer capacity- 7.2kg · 8 Washing Programmes · Child Lock · 53 cm Wide x 54 cm Deep x 85 cm High
Sep 12, 2007 | LG WFT1071TP Top Load Washer
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
