Question about Kenmore 79013 Stainless Steel Gas Kitchen Range
A Kenmore and GE gas range have recently been purchased. Both give off a toxic smell from the oven. Is there a gas range that can be purchased that does not give off a toxic smell from the oven?
    President:
  • 1,865 Answers
New Ovens may give off an odor, but it will cease after a couple uses
Posted on Apr 24, 2009
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
Kenmore gas stove
I wouldn't. The plastic will give off some very acrid, toxic fumes if you try to self-clean it. First use a damp sponge to wipe up the baking soda. After that, you might be able to turn on the oven just a little bit to soften the plastic residue, then carefully, use a putty knife to scrape up the plastic residue from the oven floor.
Aug 05, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a kenmore electric oven, which is 13 years old. i used it two weeks ago, and it was fine. now when i turn on the oven, there is a strong gas smell coming from it that not only envelopes the...
Hello Cheryl Davis...
Your posting came in UNDER A DUAL FUEL
ELECTRIC - GAS combination...
If you are smelling gas... you are in immediate DANGER.
PLEASE turn OFF the gas at the wall...
The gas is not only toxic it is highly EXPLOSIVE ...
Do not experiment with your health & safety...!!
GAS appliances are very dangerous...
A single HOT-SURFACE ignition failure
should have caused the GAS to not flow...
If it is flowing ... you are in EXTREME DANGER.
Aug 12, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
Clean oven burner
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 23, 2010 | Kenmore 79013 Stainless Steel Gas Kitchen...
Oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE oven ignitor replaced, gas turns on but no flame
Yeah, blowing up the house is never a good way to replace an appliance :)
Try contacting GE at: http://www.geappliances.com/service_and_support/contact/form_service.htm. It should be free and they'll be able to help you narrow down what's going on.
Alternately, new GE ranges start at a little over $400 at Home Depot... You certainly have to appreciate keeping a good appliance going, but if it starts nickel & dimeing you, it may be that range's time to go.
May 24, 2009 | General Electric Stove/Oven/Range Chrome...
Oven gives off strong chemical smell when it is turned on.
Hi!!! yes ignitors can go bad again its like a light bulb..its located underneath your stove..Good luck..
Just remove the 2 screws which hold it from the burner and cut the wires that go into it the new one comes with the 2 wire cap and instruction easy fix..Good luckk..
Jan 04, 2009 | Maytag MGR5751AD Gas Kitchen Range
Ge xl44 range gas smell
it's the safety valve, it's bypassing the gas. for you to put soup in there you will have to remove the oven burner. and put the soup on the tip of the orifice that's where the burner sits on.
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top of oven door is turning brown
DeBruce Polish will remove these problems on both stainless steel and enamel finishes. DeBruce Polish also works wonderfully on ceramic cook tops. DeBruce Polish is non-toxic, odor-less and non--abrasive, a true eco-friendly multi-surface cleaner. We get DeBruce Polish at debrucepolish.com.
Nov 22, 2008 | GE Profile 30" Self-Cleaning Freestanding...
Kenmore 79013 Stainless Steel Gas Kitchen Range Logo
217 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
