Question about Toshiba PH3100U1EXB 10TB Desktop External Black USB Hard Drive
Ph3100u 1exb what is the dc voltage for adopter.
2 Suggested Answers
paul7of9
  • 1189 Answers
SOURCE: My Toshiba PH3100U-1EXB external hard
Hello stxman, the best thing to do is a "System Restore." "Follow these instructions carefully!" The first thing you want to do is click on the "Start Button." paul7of9_50.jpg Next, click on "All Programs." Scroll to find "Accessories." Now; select the "System Tools." paul7of9_51.jpg"You will see in the next window that open, "System Restore." !Important, Once you click on the System Restore "shortcut." "It will start to look for the "Last known time of a change in your computer." ie. Toshiba Sleep Removal! The System Restore, can take as long as a 1/2 an hour to run! So; "Be Patient!" !Warning: "Do not try to do any type of work, don't even touch the keyboard for any reason." Once, the System Restore find: The correct {Date and Time}, of the event. paul7of9_53.jpg Coose the [Date] closest to the time of the 'occurrence'. ie. Installed [Toshiba Sleep Removal Tool]. !Warning: There will be a message: "Do not to do any type of 'work, or have applications' running' on the Computer. paul7of9_52.jpg "The System Restore will "run" for awhile; denpending on 'how far back the restore need to 'search'! The computer will then "Shutdown and Restart." Lo-gin if you have to; but! Do not touch the Keyboard once the Desktop window open. "Because "System Restore" is still running. Wait; until there is a message letting you know the {Restore of your System}, was successful!
"Please let me know if you 'need' further assistance, or the 'solution' helped? "By posting a 'Comment" or 'Rating' the solution. Thank you; your 'response' is important to me!"
paul7of9
Posted on Mar 04, 2011
How much power does my SW214-SCC need?
On the details it says :
380 TV lines Minimum Illumination 1.5Lux Output Standard CCIR/EIA (PAL/NTSC) standard video signal Lens Size and Visual Angle 6.0mm 45 Automatic Shutter 1/60 second - 1/15000 second Supply Voltage/Consumed Power 8-12V 120mW
so any AC adopter from about 10 volt will do.
Apr 18, 2015 | Home Security
I have a Toshiba Desktop Ext Hard Drive PH3100U-1EXB ... i unplugged it from my desktop to plug into my laptop like i have done before but this time it wouldnt load so i tried to eject it but it wouldnt...
but does it still work on the desk top.
if yes, then you have lap top issues, ONLY.
easy ,huh?
try all lap top USB ports no ext. hubs allowed.
what is wrong in the LAP top OS, unstated)
are you using the correct external power adaptor for both Desk and lap top usage,
have you tried a diff. usb cable.
Laptops can not power the hdd via the USB at all, and in fact
should be avoided at all times. no matter.
the laptop can be infected.
the laptop might have USB issues, with drivers.
do a USB driver update. (no 0S stated)
does the HDD show up in Disk manager, as DISK2
can you set the drive letter?
can you set the volume label on this disk via DM?
if yes, you then can read and write the drive.
as stated on all pages for USB
disconnect all other USB devices, and now try this HDD.
do a full virus scan, and malware scan
do wInDoZ update.
I think i hit them all.
Oct 01, 2013 | Computers & Internet
Power off ac adopter is ok
remove the rear cover then tried to make a voltage checking since as you said the power adapter is good so what you need is a voltage checking going inside. you need a digital tester then make a voltage checking at the lcd control board if the dc supply goes through or not present. you can check also a bulged capacitor or burnt parts at the lcd control board.
Aug 09, 2012 | Dell UltraSharp 1701FP 17" LCD Monitor
Black screen on my aspire one and no noise to indicate it is on. The power light is on but will not boot.
Open the battery from the back side and connect power cord without battery. Pust the start button now.
Also you need to make sure in that case that your power adopter is supplying the necessary voltage (12-18 volt DC) - If not then you need to change the power adopter.
IF not untill that point. Safely open back cover and release the RAM and after cleaning dust put back. Now try, hope it will work.
IF not then need to check physically by an expert.
Aug 06, 2011 | Computers & Internet
My Toshiba PH3100U-1EXB external hard drive (1tb) is not being recognized properly. Windows detects the device but unable to install it. This issue started after trying to install the toshiba sleep removal...
paul7of9
Feb 26, 2011 | Toshiba PH3100U1EXB 10TB Desktop External ...
Formatting an external hard drive
Open up Folder Options\View\Show Hidden Files and Folders. Return to your Toshiba HDD. Do you see an hidden files? If so, try to delete them. You may have to change the Properties of these Folders\Files in order to delete them. BE WARNED, removing or deleting any folders or files that Toshiba placed in there could have negative affects on the way your external HDD runs.
Mar 18, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Light is not on
check the power adopter output voltage 16V dc and 32V dc.if the adopter is working change the printer logic board
Sep 04, 2009 | HP DeskJet 3550 InkJet Printer
DC port?
check adopter may be replace with any other laptop adopter....
May 04, 2008 | Sony VAIO GRX520 Notebook
DELL LAPTOP PP19L - INPUT POWER FROM ADOPTER SHORT CIRCUITED - TO BE FOUND OUT
sounds like the charging circuitry is faulty. I was looking at the service manual and it looks like it is on the motherboard.
Here is the online manual, see what you think.
http://support.dell.com/support/edocs/systems/ins630/en/sm/index.htm
Dec 02, 2007 | Dell Inspiron 2200 Notebook
Toshiba PH3100U1EXB 10TB Desktop External  Black USB Hard Drive Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
