Question about Home
Leaks from jets along outer wall
I have a cultured marble jetted bathtub that has a leak coming from the jets? located along the outside window side of the tub - can this be fixed - no plumber here wants to tackle this - it is an enclosed tub that would have to have the surround marble pieces that are grouted in removed to access those jets - what do I need for parts - this house was built in 1984 - motor control is on the wall away from the tub THANK YOU
  • Dan Damron May 11, 2010
    Do you have a raised floor or is it concrete or is it on second floor?
    Scholar:
  • 80 Answers
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Posted on Aug 19, 2009
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
Can I simply silicone jets in a tub to seal them completely, so the jets don't leak? It's for a rental unit I own, bathroom on 2nd floor. Don't want to tear out the bath tub or ceiling on Main floor.
In order to properly seal the jet in place with silicone you must remove the wall fitting from the inside of the tub. The wall fitting is threaded into the jet body from the inside of the tub.
Once the wall fitting has been removed you can put a small bead of silicone around the underside of the flange and thread it back into the jet body. Clean up the excess silicone after it squishes out with DeNatured Alcohol.
If you plan on just putting a bead of silicone around the outside edge of the jet body behind the tub, do not waste the silicone or your time as it will not solve the leak in the tub.
US Parts Center
Sep 12, 2013 | Jacuzzi - Bathtub - Alcove - Navona -...
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
I have a marble jet bath tub. is there anyway to cap the jet holes, so it is no longer a jetted bath?
You should be able to remove the access panel and just disconnect, and cap the hose that is connected to the pump for the jets and then cap the pump nipple, where the hose connects.
This would likely be easier than trying to locate multiple caps to plug the jet holes in the tub.
I hope this helps you.
Feb 02, 2011 | Jacuzzi - Bathtub - Alcove - Navona -...
I have a Jacuzzi brand bathtub/whirlpool 6 years old. One of my jets leaked and created a significant damage downstairs. How can I fix the jet, how can I prevent other jets from leaking? Can I just kill...
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Sep 12, 2010 | Jacuzzi Home
We have a leak on the backside (wall) on our Fiore
if the tub is leaking from a jet, you have to get to it to remove it, put a bead of silicone around the wall fitting and reinstall it. no other way.
Nov 10, 2009 | Jacuzzi T601-959 Fiore Whirlpool Bath...
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Mar 24, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
477 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
