Question about Samsung Washing Machines
Washer not spinning - Samsung Washing Machines
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Washer no longer spins.
with the washer set for spin and turned on...raise and lower the lid.
If it spins replace the timer.
If it does not spin...replace the direct drive coupling on the motor.
Mar 11, 2009 | Whirlpool LSQ9600L Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
