Question about Singer Quantum XL-6000 Computerized Sewing Machine
Top thread bunching and stops sewing after about 4 stiches
  • 323 Answers
SOURCE: model 4832c
guide the the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)If it doesn't work like this, then there is probably thread stuck inside the tension assembly. Set the tension to zero and blow hard between the discs to dislodge the thread. If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
Check to be sure you have the correct bobbin and that it is inserted the correct way.
OR remove the needle plate to remove the bobbin case. Look for any burrs or rough spots. Use a fine emery stick and steel wool to remove and buff them Reassemble and try again.
Sewman7
Posted on Jun 18, 2008
dupina
  • 110 Answers
SOURCE: Persistant beeping
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down. Good luck!
Posted on Nov 04, 2008
  • 6 Answers
SOURCE: Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Posted on Mar 24, 2009
WonderTech
  • 268 Answers
SOURCE: get everything threaded and when I go to sew it
Here's some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs
If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps you.
Posted on Oct 02, 2009
  • 255 Answers
SOURCE: THREAD GET BUNCHED UP UNDERNEATH THE FABRIC
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Posted on Jan 27, 2010
My stiches are uniform but about every 12 stiches there is a long stich , can you tell me what is causing it?
try to decrease top thread tension a 1/4 notch
check with new needle (may be bent and hook is missing the thread loop)
Nov 10, 2015 | Sewing Machines
I was in the middle of a project. This keeps happening, the thread & bobbin won't allow me to make a single stich. I've tried to take the bobbin out, rethread it, and rethread the top. Can anyone help
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? xz
May 21, 2015 | Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
Bobbin always jams, thread bunches up under fabric, auto winding causes a birdsnest of ruined, loose thread and most importantly it won't sew.
Your tension is not set right. The tension setting is usually around 4 and can chang e depending upon the fabric you are using. Hope this helps.
Dec 10, 2013 | Singer 2250 Tradition
Thread bunching up on the bottom
try changing the needle
rethread the machine top & bobbin
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for lint or loose
thread
Aug 23, 2012 | Sewing Machines
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Robbie
Jan 27, 2010 | Singer Sewing Machines
Singer sewing machine stiches not forming & thread bunching
Sounds like what is called bird nests or thread nests. The top thread is not seated completely in the tension disk.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Now, retest your machine.
Jun 28, 2017 | Singer Sewing Machines
Bottom stich from bobbin is bunching up.
Make sure you have the bobbin in the correct way round and make sure you have gone completely through the tension discs when threading the machine, make sure the top tension is set properly.
Nov 01, 2009 | Janome Memory Craft 9000 Computerized...
Sewing problems on Singer 132 featherweight
Your top tension must be set on 5 or there is some cotton/fluff stuck in your top tension unit or you have no tension on your bobbin case
Oct 04, 2009 | Singer Featherweight II 117
Singer Quantum XL-6000 Computerized Sewing Machine Logo
15 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
