Question about Maytag Dishwasher
My GE QuietPower 3 soap dispenser door won't stay closed. What could be the problem? The latch to is there to latch the door closed looks ok.
Illeagle
  • 525 Answers
SOURCE: soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 04, 2008
  • 338 Answers
SOURCE: soap dispenser door doesn't open
make sure you have 120 going to the ax motor.. if you dont then replace the control.
Posted on Dec 01, 2008
rylee_smith
  • 8619 Answers
SOURCE: dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Posted on Feb 10, 2009
  • 254 Answers
SOURCE: Maytag MDB7601AWW door will not latch
possibly need a new door latch assembly this is kind common on those maytags the latch assembly becomes defective or doesnt latch properly...W10130694 is the part number for the replacement part u would need you can see a pic of this part at repairclinic.com just enter the part number. you could purchase it there or online thorugh sears or etc... also check local they might stock at and be cheaper with no frieght shipping charges......to change this or check your assembly prob have to remove all screws from inside door usually a torx bit this will seperate panels and control will pop off.. hope this helps
Posted on Feb 06, 2010
  • 47 Answers
SOURCE: latch on door dosn't lock when door closed
there is a ajustment or the latch is broken
Posted on Feb 10, 2010
Why does it keep dispensing soap?
What do you mean "keep dispensing soap"? Is this a GE dishwasher with an automatic soap dispenser? Or do you mean that the soap lid won't latch or stay closed? Or are you talking about the rinse-aid dispenser leaking rinse-aid (which is fairly common)?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 11, 2015 | Dishwashers
MY SOAP DOOR WONT STAY CLOSED
Soap dispenser latch problem.
a) Look at the latch whether there is build up of soap. CAREFULLY clean it. It might work.
b) If not just replace the whole dispenser unit. Not worth wasting time on trying to fix the spring problem. Most dispensers are $ 50 ~ $ 100 price range.
Sep 26, 2014 | Dishwashers
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Soap dispenser will not close stays open will not latch
Turn off power to the machine. Remove the inner door panel and inspect the dispenser cover latch for any broken components. If everything looks ok, check the action of the release solenoid by hand. If it is sticky or stuck closed, try removing the center pole piece and clean the solenoid interior and pole piece with a small rag or 'Q tips' with WD40. Don't otherwise lubricate the solenoid. Push the cover closed and push the solenoid pole to release the latch, then repeat the process again. If the cover will latch again, you can replace everything and try a load of dishes. Hope this helps
Mar 29, 2010 | Bosch Dishwashers
Triton XL detergent dispenser won't stay closed
Well this is not a solution by any means but I would just put the tablet or powder directly into the machine-just "chuck it in". It will work just the same. The dispenser itself isnt truly necessary.
Jun 21, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Dishwasher Logo
131 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
