Black line when using feeder
HP Office Jet J6480 All of a sudden there is a black line running down the center of the page. But only when faxed or copies using feeder. Doesn't happen when printing or using the flatbed. How do I get in there to clean?
  • brent493 Apr 27, 2009
    Hi:
    On this model when you use the document feeder it does not go to the main contact glass. It basically has two scanners: the flatbed and the fax/scan.
    i need to get into the fax scanner somehow.
    Thanks for trying!
    OK I get it now.
    Well not sure what to think.
    I tried to jsut use a tissue.
    Ran through a blank page.
    The print out still had the blank line.
    But dig this, it had something stuck to it that looked like a catepillar.
    It some kind of little brush.
    Seems like the whole unit is suddenly melting down!
    Thanks.
Not familiar with this model in particular, but if you lift the document feeder, as if to place an original on the glass, there is either a narrow filter glass on the left of the main contact glass, or in many cases it is attached (clipped on) and lifts up with the document feeder cover. Clean this glass. If it is clipped on to the cover, remove it, and clean both sides. I hope this helps.
Please rate solution :)
Posted on Apr 25, 2009
  • Anonymous Apr 27, 2009
    Ok, so you have to actually lift the Feed section of the Document feeder to access the Scanner glass I was talking about. There are not 2 scanners, and as I said I'm not familiar with this model exactly, but they are all similar in function.. Clean the narrow glass on the left side...look in your user guide on page 134 if you are still not clear. Get the guide here, if you need even MORE help. I can't provide any more info than this.
    http://h10025.www1.hp.com/ewfrf/wc/manua...
HP OFFICE JET J6480 ALWAYS SPEWS OUT EXTRA BLANK PAGE AFTER PRINTING
Check if your document has empty lines at the end. Use your keyboard down arrow to scroll past the last line of text. Then backspace until you get to the last line.
Mar 09, 2016 | HP OfficeJet Office Equipment & Supplies
My HP OfficeJet J6480 All-in-One is leaving black vertical streaks on each side of the page when using the document feeder. Does not leave streaks when using the flatbed scanner. How do I correct
Hi
Just remove the ink cartridge. Clean the print head by a soft cloth with rubbing alcohol to remove some sticky or ink residue. Then rub the printhead into a plain paper until ink flows. Then run the print nozzle for 2 times.
I hope it helps you. Regards
Apr 09, 2011 | HP J4680 Office Jet All-In-One Printer
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
Black line running down center of page
hi there
it seems like there could be some correction fluid or dirt on the scanner glass.pull open the document feeder and the glass can be seen .us a damp rag and wipe the glass this should solve the problem
Oct 26, 2009 | HP 1040 Plain Paper Inkjet Fax
I have an HP J6480 printer, Fax copier, when I fax or copy a black line is down the center of the sheet. I replaced the toner. How do I fix it?
There is something stuck on the scanner glass. To test for this problem try making a copy by laying your original on the glass and making your copy, not running it through the feeder. If it copies fine from the glass it is definately something in the feeder/scanner glass. Just clean it with a soft cloth and some glass cleaner. You should be lookig for a thin strip of glass to the left of the large glass. Or you might have to open up the feeder unit and find it there.
Oct 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
Black line down my faxes
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
Jan 30, 2009 | HP J4680 Office Jet All-In-One Printer
Black lines showing up on documents fed thru the document feeder.
Clean the small glass under the doc feeder very very well...
Jul 03, 2008 | Sharp AR-M277 All-In-One Printer
HP office jet J5740 all in one/Black line
are u trying to fax from the feeder or from the scaning bed .... try to follow this link CLICK HERE
Jun 06, 2008 | HP Officejet J5780 All-In-One InkJet...
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
LINES DOWN THE PAGE WHEN I USE AUTO FEEDER
sounds like you need to do a head cleaning. go to control panel on computer and click on faxes and copiers. right click on the printer you are have problems with and there will be a head clean and nozzle check choice run through those.
Oct 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
408 people viewed this question
k24674
jasbo
jasbo
