Question about PfaFF Sewing Machines
I have a one year old Pfaff Creative Sensation; love it but the bracket INSIDE the tension area that holds the removable cover keeps breaking. 1st time it was able to be fixed, this time the 'certified' Pfaff repairman says he may not be able to repair it. it this inherent or unique? I RARELY remove the cover, no need to.
3 Suggested Answers
talk2ginny
  • 34 Answers
SOURCE: Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Posted on Feb 03, 2009
  • 6 Answers
SOURCE: removing top cover on pfaff creative 4.0 embroidery machine
May be, you have not the right tools to open your pfaff chassis. In your case I prefer to get support from pfaff: http://www.pfaff.com/de/692.htmlIt's a risk to open the chassis, you can't see, where it is fixed. If you try to open, the risk is high your pfaff will take damage.
Posted on Sep 30, 2012
What size bobbin for a pfaff creative sensation
Bobbins (10pk), Pfaff #820921096: Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts > Creative 2.0
  1. Cached
  2. Similar
Product Details. Guaranteed to fit Pfaff Sewing Machine Models: Group J: creative sensation, creative sensation pro, creative performance, creative vision, ...
Pfaff - creative sensation™ pro
www.pfaff.com/en-US/Machines/creative-sensation-pro
  1. Cached
Now your PFAFF® creative sensation™ pro can embroider faster than ever ... needed to achieve perfect balance between the needle and bobbin threads.
Pfaff - Accessories
www.pfaff.com/en-US/Accessories?page=5
  1. Cached
Results 161 - 200 - Revel in a wide range of PFAFF® accessories .... blue bobbins for sewing, embroidering or experimenting with the creativeBobbin Case. bobbin for pfaff creative sensation Google Search
Dec 31, 2016 | PfaFF Sewing Machines
My pfaff creative sensation shuts down and starts up again when press sew button or put pedal down. What is causing the overload. I cleaned it. There are no threads caught in bobbin
You may have an old style transformer and/or a hook that is not grounded.
Both parts are not repairable, they need to be replaced.
Also, it could be poor grounding of front cover and circuit boards.
A dealer will probably have to do the work.
good luck!
Sep 01, 2016 | PfaFF Sewing Machines
I need to access the tension plates on my Pfaff creative 7570
To access the tension disks, remove the top of the machine as follows: 1. With the carrying handle raised, remove the cover (the piece that has all the stitches pictured). 2. Unscrew 2 screws completely; one is in the depression where the thread spool goes and the other is right behind the bobbin winder. 3. pull straight up. You may have to jiggle it a bit. 4. you should be able to see the tension disks from here.
Apr 16, 2014 | PfaFF Creative 7570
Needles keep breaking when i quilt, its like they dont fit or too long quilt expression 4.0
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Jan 09, 2013 | Sewing Machines
Removing top cover on pfaff creative 4.0 embroidery machine
Sep 30, 2012 | Pfaff Creative 4.0 Sewing Machnie
I cant set the tension on my PFAFF 7570 the thread keeps
First make sure your needle is in correctly. Then make sure you are threading the machine correctly especially make sure you thread the take-up lever. Make sure your tension dial is at a 4 to 5. if this does not work, let me know
Oct 19, 2009 | PfaFF Creative 7570
Pfaff Creative 7570
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}You need to do a tension assembly test
Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air( a needle will work also). The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 18, 2008 | PfaFF Creative 7570
Thread bunching underneath fabric as I sew.
You may need to take off the housing that covers the whole dog mechanism. You will need a screwdriver to do this. Blow out the area around the tension gears and dogs, check for loose or disconnedted parts, and re-oil the gears. Fleece fuzz usually collects where you can't see it. This was the problem with my machine that had the same symptom.
Jun 02, 2008 | PfaFF Creative 7570
Loose end cap cover.
This actually applies to most of the newer Pfaff machine models:
  1. If the cover will come completely off, look at the inside of it to make sure the bracket that holds it in place is not broken. If it's not broken...
  2. Grab a flashlight
  3. Remove the stitch lid - there are little silver clips at the base of the lid on either side - push the lid either to the left or right against these clips and you'll be able to pop it right off. You will reverse procedure to put it back on. Removing the lid isn't absolutely necessary but does make it easier to see/access screw.
  4. Raise the handle of the machine
  5. Aim your flashlight into the machine behind the left side of the handle... you should be able to see down inside the machine to the set-screw that holds the side cover in place
  6. Check to see what kind of screwdriver you need - either a Phillips head or a Torx Driver. Most of the newer Pfaff models require a Torx Driver (this is a star-shaped screw-driver available at most hardware stores - Size T25 should fit this particular screw)
  7. Slide cover back into place - may need to wiggle it a bit to get the bracket under the screw
  8. Tighten screw & you should be back in business
If the bracket on the inside of the cover is broken, this part will need to be replaced. Pfaff parts are only available through an authorized Pfaff dealer so your local dealer will need to order it for you.
Hope this helps - please don't hesitate to respond if you need further help or clarification.
Happy sewing,
Kim & Linnette
Dec 20, 2007 | PfaFF Tiptronic 2030
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
