Question about HP Office Equipment & Supplies
How do you change the settings on an HP 4650 DN to recognize an added tray 3?
    Sergeant:
    Champion:
  • 219 Answers
Hi, You can get the instructions from user manual of your HP printer. I can not write it as u wont be able to understand it properly.The manual consist of clear diagrams and pictures which will make you understand it in a better way.
The settings are there on the 49 page and 68 page of ur user manual.If u dont have the manual.Please go to below link:
http://www.scribd.com/doc/3944904/hp-laserjet-4100-users-manual-guide
I hope it solves your problem. Thanks! Sandy
Posted on Apr 24, 2009
I cant get my printer HP2055 dn to print letter paper..it just goes to the legal tray (3). I also can't figure out how to get to the menu on the printer to see if the trays are set correctly.
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
Feb 12, 2013 | HP LaserJet P3005n Printer
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
May 13, 2010 | HP LaserJet 4650 Color Printer Manual...
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Business cards get stuck in HP 4650
The card stock is most likely too heavy for the 4600. If you check the owners manual, you will most likely find this is "Out of media specifications".
Other color HP laser printers like the 2500 cannot move card stock well either.
HP will tell you that 'if the printer moves paper perfectly' it's not broken.
Mar 12, 2009 | HP LaserJet 4650 Color Printer
Printer will jam on mulitiple page print jobs gets a 13.1 error all rollers have been changed, jams just after the letter tray and only jams from legal tray 3 ???????
OK you said you replaced the rollers. If you have not repalced the SEPERATION PAD, (located directly under your pick up roller....thats your problem. Easily done.
Hp laserjet 4650 crumples leading edge of paper
When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
Oct 01, 2008 | HP LaserJet 4650 Color Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
HP LASERJET PRINTER #4250
GO IN PRINTER MENU ON PRINTER AND UNDER PAPER HANDLING OPTION AND SET OR SIMPLY SET PRINTER TO RESET FACTORY DEFAULTS UNDER DIAGNOSTIICS MENU
Jan 17, 2008 | HP LaserJet 4650 Color Printer Manual...
35 people viewed this question
Seeker5211
Seeker5211
