Question about Whirlpool Duet GHW9150P Front Load Washer
Water seaps into washer when turned off
When the machine sits for a day water accumulates inside the washer. We need to run the spin cycle before we can add a new load.
About a quart a day accumulates.
    Problem Solver:
  • 4 Answers
Sounds like your pump is not getting all the water out during the spin. take off the lower front panel and clean out the filter o n your pump, this fixed mine.
Posted on May 08, 2009
    President:
  • 414 Answers
Shut the water off to the washer when not using it.
Posted on Apr 24, 2009
  • Mark Gough Apr 30, 2009
    I wrote that because it has happened to our machine and it was the est way tosolve the problem and save water.
  • Mark Gough May 04, 2009
    I you still have this problem take it to a service center.
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
After a wash cycle, there is water sitting in the gasket around the door. This water smells after a few days. What is to be done?
Make sure the washer sits level front to back and side to side. Wipe away any water and leave the door ajar to let the inside dry out. If the whole washer insides smell, run an empty cycle with hot water, detergent, and baking soda to refresh. Hope this helps!
Oct 17, 2010 | LG WM-2277HW Front Load Washer
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
How to clean the inside of the machine
Go to the store and buy a bottle of CLR. Run a few cycles of it (without the clothes in there, of course!). Make sure you run a few cycles of just straight water before you attempt to wash clothes. That should do it. I've also heard of people using powdered lemonade to clean the inside of dishwashers, too. Maybe try the powdered lemonade first if you're squeamish about damaging something.
May 21, 2009 | Hoover HTC243 Top Load Washer
Water is leaking from the door especially when on fast spin
you need to get a new rubber door seal u can get it from this website http://www.4hotpoint.co.uk/cgi-bin/home.pl?gclid=CMKHz4OM05wCFZMU4wod5HwDKw to replace it you take the clip off the front of the washer the peal off the seal off the frame and the do the same off the drum then but the new one on.hope this helps.
Apr 13, 2009 | Hotpoint WMA48 Front Load Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Water runs during spin cycle
I would suspect that you timer is shot, only during spin? During the day when water use is high does it leak then?
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
