Question about Stanton STR8-100 Turntable
Remove platter stanton - Stanton STR8-100 Turntable
    Sergeant:
  • 432 Answers
I know the problem, don't going pulling hard. Give a little knock with a small hammer en voila, the platter is loose. If not, let somebody
pull the platter and give a knock on the spindle(first use a bit thin oil from above, non aggressive, bike chain lubricantoil is perfect) and then it's easy. But pulling has no use, While a hammer does wonders.
Succes, richard
Posted on Oct 08, 2014
2 Suggested Answers
  • 31 Answers
SOURCE: platter wont spin on stanton
The belt that drives the platter may have shifter or the gears that turn the platter may be unaligned. Open it up yourself and check out the inside but be careful not to break anything or go into a local music/dj store. they may be able to help you for cheap or for free.
Posted on Mar 02, 2011
Stanton str8 80 wont spin anymore
Remove the platter and check the drive belt is fitted correctly. Keep em spinnin, John. Stylus City.
Feb 27, 2014 | Stanton STR8-80 Turntable
How to fix a wobbly turntable stanton T.50
Check if the platter is oke and aint stock, and otherwise is you spindle bearing defect.... A platter ain't goes from flat to wobble all of a sudden. And try to get the stuf second hand, or better, buy a better unit, not from stanton, but a refurbished 1200mk from technics is ok, if you sprin records. If you only listen, take a loke at the rega and pro-ject sites.....
Jan 01, 2014 | Stanton T.50 Turntable
Stanton t.80 Motor produces hum sound when holding the platter to cue. When platter is released the hum disappears. Also is a slight hum on start up. Have opened the turntable and all connections seem to...
Do you keep the platter at one place --> don't you let the platter spin and keep the record at. one place, you are know f.5;5,g your engine and parts.... buy suzuki slipmats and use the plastic rounds of plastic .... i thought by thud rumble too let your table spin when you hold the the platter, otherwise components get to hot
Aug 03, 2013 | Stanton Audio Players & Recorders
Stanton str8 60
The Stanton STR8-60 is a direct drive record deck, so this shouldn't happen unless the platter was damaged but after a little research I found that the Stanton's can get a faulty chip which is meant to regulate the speed and therefore can make it spin erratically.
Jun 14, 2013 | Audio Players & Recorders
Replace turntable belt
To replace a drive belt.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Apr 26, 2013 | Stanton Audio Players & Recorders
Stanton str8-20 belt size???
HI,
If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
OK
Dec 11, 2012 | Audio Players & Recorders
My stanton str8 100 makes a rubbing noise when its turned on
Rubbing as in its grinding or just a like its in motion its normal to hear some type of rubbing as the platter spins because if u notice when u push down on the platter it has some play you can clean the inside by removig the platter and cleaning and dirt and dust
May 18, 2011 | Stanton STR8-100 Turntable
Platter wont spin on stanton t 120, all the lights turn on fine, platter seems to feel jammed, it wont spin easily when i push it by hand.
Mar 02, 2011 | Stanton T.120 Turntable
Belt fell off my stanton turntables, so it will not spin
Ok, so put it back on.
It's very simple, just take the platter off, and out the belt on the bottom. Then put the platter back on, and you'll have to pinch the belt off the platter, and wrap it around the motor shaft.
- Davis
DJ Pro Audio
www.djproaudio.com
Jul 14, 2008 | Stanton STR8-50 Turntable
Stanton STR8-100 Turntable Logo
137 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
