Question about Car Audio & Video
Factory radio won't play CD's, just shows an error code on radio display. Radio does work fine though.
  • 55 Answers
You will need to send it to repair or just get new aftermarket radio and save yourself a lot of headaches
Posted on Apr 24, 2009
Radio CD code for a 50645P 2003 Hyundai Santa Fe.
Trent, with any factory systems you must grab the vehicle's VIN or have your registration and call Honda Service or Parts they will be able to provide you with the code. You will need the radio and CD changers serial numbers. Hope this helps buddy, let me know if it works for you. Lex.. 11_2_2013_3_10_53_pm.jpg
Oct 10, 2013 | Car Audio & Video
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Audio & Video
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
Nov 20, 2017 | 2004 Chevrolet Tahoe
My cd player will not work but radio works fine
in the unit cd player and radio are two different things.so just check out with another cd first to confirm the fault.also if it shows "no cd error code" that means either the cd is faulty or the internal cd lens is faulty so its not reading the cd.but if its showing no such error and display is blank then,first try cleaning the cd tray with tissue paper and check if still the same problem its internal circuit error that needs to be checked with multimeter and repaired.mostly the repairing cost of circuit is minimum.
Aug 30, 2009 | Philips Car Audio & Video
Err code displays when i put a cd into my radio.
the cd player only is the problem even though it is all in one unit the radio will still play. tr a different disk if no luck then unfortunatley the problem is in the radio itself. you can buy a nice after market radio for alot less money. keep me posted thanks
Jan 31, 2009 | 2003 Chevrolet Malibu
Error Codes
I've had a friend to stay who had this problem. I downloaded the user manual from the internet and the error code is not mentioned. I followed the procedure to reset the radio and this solved the problem.
Take the cover off the stereo and locate the small hole (towards the centre) which houses the reset switch. Insert something like a paper clip into the hole and hold for a few seconds. Then replace the cover and all should work. You'll loose all the radio presets.
Jan 09, 2009 | JVC KD-G322 CD Player
2002 Altima Factory Bose Audio ERR3
there are only couple options. pull radio and send to shop for repair, purchase used radio from good junk yard. or call dealer and see if there is a warranty on it. even though its 6 yrs old they may help. what they do at the dealer is an exchange
Nov 16, 2008 | 2002 Nissan Altima
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
