Question about GPS
Garmin nuvi 2300 keeps rebooting
My problem the unit would show up and the loading maps ..text would show up and right at that moment the unit would restart looping in this pattern
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
Rafiandi
  • 35 Answers
SOURCE: Garmin Nuvi 200W keeps rebooting after 2009 maps
Try to hold the power button to the left for approximately 15 seconds, then release it. It should then reset and turns ON. I hope this helps.
Posted on Jul 15, 2009
pabloloco
  • 2335 Answers
SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Posted on Jan 15, 2010
pabloloco
  • 2335 Answers
SOURCE: Garmin Nuvi will not load maps - why
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
I hope that helps.
Garmin nuvi 2300 keeps freezing on "loading maps"
Open the unit . Disconnect battery which is probably under the pcb/board and leave for 5 min.That should clear most problems.
Nov 13, 2013 | GPS
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
Garmin Nuvi 1350LMT Nuvi 1350 W map update error
Run the Garmin WebUpdater once more and apply any updates. Consider downloading and installing the lifetime map update to the computer and then use the Garmin Mapquest or Basecamp computer program to send the map data to the nuvi. Overall, it takes a little longer, but is better than trying to download directly to the GPS itself. If you're not having luck, it will probably be wise to contact Garmin Tech Support. It would be wise to mention the funky "once / month" GPS reboot issue with Garmin at this time too.
May 10, 2012 | Garmin Nuvi 1350LMT
My Garmin gets stuck on the garmin screen saying loading maps. I have tried to the reboot option of holding down the right corner power on and then click yes to erase maps however when i click yes nothing...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
Nuvi 205W keeps rebooting.
Your unit most likely has a firmware error, which could be due to a corrupt file. To solve it you yourself can try to update the firmware when connecting to the pc, if the unit cannot stay on enough for this to be performed, your unit will have to be sent in to service.
Jun 02, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 200 after upgrading drivers, it keeps on saying cant unlock maps. How do I fix\ unlock maps if iI havent loaded any new maps
Click myMaps
Click Manage Maps
Close the document
Regards
Richard.
May 18, 2009 | Garmin nuvi 200W GPS Receiver
Click myMaps
Click Manage Maps
Close the document
Regards
Richard.
May 15, 2009 | Garmin nuvi 205 GPS Receiver
GPS would not turn on
Have you already tried the webupdater or registred the device on garmin.com? There you should get an free mapupdate which could replace your broken maps.
Dec 01, 2008 | Garmin nuvi 205 GPS Receiver
I have a Garmin 350 that won't load maps and stays frozen what can I do to fix problem
Have you tried a software upgrade. Talk to Garmin, they were pretty helpful when I talked to them.
Oct 07, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
