Question about Leisure Cookmaster CM101NR
Grill will not stay alight - Leisure Cookmaster CM101NR
THE GRILL ON MY ZANUSSI ZXC662GXC COOKER WILL NOT STAY ALIGHT
you will need to contact your local Gas Safe service engineer, you are not permitted to repair this yourself. check the Gas Safe website to find your local service engineer.
Sep 03, 2016 | Zanussi Ovens
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
I have a stovesGG600 cannot turn on the grill the knob wont turn in that direction any more and i have to turn off the gas as it stays alight after using the oven do i need to replace the whole thermostst...
Sounds like you need to adjust the actual burner valve and not the thermostat control. If they are one in the same try adjusting it. Remove knob and look down the shaft there may be an allen adjusting screw in there
Jun 10, 2014 | Stoves Newhome ECH600MXa Electric Kitchen...
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
Apr 13, 2010 | Thetford Refrigerators
Diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Nov 05, 2008 | Ovens
Low gas pressure
Spiders like to overwinter inside the nozzle attachment. A blast of canned air should clear it out.
Apr 14, 2008 | Weber Q Grill
Leisure Cookmaster CM101NR Logo
Top Leisure Kitchen Ranges Experts
Timllfixit
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
