Question about Microwave Ovens
Please stop loading incredimail page its driving me crazy
How do I turn off the sound?
what does opening the door do . mine shuts the noise off which I do not hear but wife says drives her nuts .
Dec 11, 2014 | In Microwave Ovens
Ge microwave # JVM 1660 = beeping problem
see this video and proceed according. God bless you
Oct 01, 2012 | GE JVM1660 Microwave Oven
Kitchen aid model 45sm50pwh stopped working - sound like a drive belt off or gear stripped or ?? In order to dismantle, I believe I need to drive the pin holding the mixer part (?) under which there are a...
Hi and welcome to FixYa, I am Kelly.
You need to download and peruse this manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
See page 6 about removing the pin (figure 4) and planetary access bottom of the page and page 7.
There is yet another pin that must be removed on page 7, figure 6 to get the gear case cover off.
The manual is loaded with all the information you should need to inspect and repair your mixer.
Thanks for choosing FixYa,
Kelly
Apr 24, 2011 | Microwave Ovens
The oven (10+ years old GE True Temp double wall oven) beeps and displays an F7 error message. We can temporarily stop it by pushing the Clear button, but it starts again in a few seconds. We don't know...
I'm a GE tech, the F7 means there is either a stuck button on the keypad or relay on the board behind the keypad. Shut off the breaker. Remove the 3 screws under the keypad and lift the panel a bit to remove it. Lay it face down on the top rack and disconnect the ribbon cable. Turn power back on and if f7 goes away the problem is in the keypad. If f76 returns it's in the control. We typically replace both together because usually if you replace 1 it will come back later then be the other part.
Mar 26, 2011 | Microwave Ovens
Sharp R-1750 Microwave
the door switches need adjusting. remove casing and adjust door switches
Jan 25, 2009 | Sharp R-1750 Microwave Oven
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
