Question about Audio Technica Audio-Technica ATR-20 Professional Microphone
My windows laptop does not detect the mic when i plug it in. it used to, and i know that the mic works
  • 3 Answers
If using windows 7 go to sounds then properties then go to microphone than make sure enable after that test levels
Posted on Oct 14, 2013
No audio input
to set a microphone you do not need to get to the speech folder..That folder is for other things ...
just insert the mic..and go to the control panel ..and open the sound manager ..In there select record ..and after that select the mic .
click on set default if you have only one sound card ..and not using any digital cables..and than configure...from the list select headphones or desktop mic...and go with the wizard ..It should show the signal being received and next when the progress line react on noises..
usually the mic should work right the way if it is plugged in the pink in for mic on a desktop and for laptop ..just open the speaker configuration and select headphone if it does not detect the mic..(this enables teh jack plugs for some laptops..
if you have a windows xp ..just double click on the volume icon on the bar ..and volume manager will start ..In the list look for the mic..raze volume and un-mute ..If the mic is not in the list ..click on options ..and properties..(top left ) ..and tick the mic case .This will display it and enable it ..
Jan 10, 2012 | Sony Vaio VGN FS215M Laptop Universal AC...
In my hp compaq nx7400 laptop,mic was not detect voice how to identify that what's the problem
most of some notebook computer had only mic capturing, when you talk someone on voicechat, they heard you but you can't hear on your notebook built-i speaker. if you want to check., if your mic is ok...try to record voice....using sound recorder of Windows.
Feb 19, 2011 | HP Compaq nx7400 Notebook
How to configure a headset with mic?
Headset will have two pins .plug the pin initially
The green pin should be plugged to speaker and the red pin to the mic.
In the volume button select the advance properties and increase the volume of mic .sometimes it may be in mute if so un mute it.
Ensure proper drivers are installed and mic is detected i the system.This can be seen from the sound devices option in control panel .
To check whether mic is working try to record using the sound recorder which is present in system
Mar 04, 2010 | Computers & Internet
How to install my microsoft lifecamVX-1000 inorder to chat my friends with web cam?
to chat with ur friends u will need the foll:
WebCam, Mic, and Speakers.
Alss u will need to have either Yahoo Msgr, or MSN Mgr etc
u need to connect the Webcam using the USB port and once the Webcam is detected by your OS (i assume u use Windows) u may have to install the driver for the Webcam(the CD that came along with the Webcam will have the driver)
inster the CD in the CDR/DVD drive and let the machine install the device....once it's doen u r set
Mic and Speakers r normally Plug and Play devices and they just need to be connected to PC/Laptops sound card/Mic ports in you machine and they will automaticaly work.
Dec 09, 2009 | Microsoft LifeCam VX-3000 Web Camera
Advent 5313
Make sure you have not started your WEB cam.
Start Skype then click on Tools - then Options - Audio Settings then select your Microphone.
Then click on Video settings - then select your webcam, your image should now appear.
Select your Receive and Show video options - suggest you use
Only people in my contact list
Click SAVE (your settings)
To add people to your Contact list - Click on Contacts (at the top) - then New Contact and follow the instructions.
You can also test your Skype by click on Echo / Sound Test Service.
If you still have problems, get back to me.
Have fun
Apr 22, 2009 | Compaq Presario Notebook
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Creative HS-400 headset & Mic
I had the same problem... with my laptop, using vista. I plugged the mic dirrectly into my laptop and for some miracle, it works! try it out! ^-^
Sep 25, 2008 | Creative Labs HS-400 Headset
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Using Skype - Intneral mic no longer works
Its due to your internal laptop MIC's failure! Plz check at any Compaq Service station! Becoz its internal hardware error! Becoz there r no seperate drivers for MIC! If your speakers are working great then MIC should work or else try to get repaired it!
Dec 02, 2007 | HP Compaq Presario V2000 Notebook
Micro phone not working in my DELL Inspiron 6400
There is NO built in microphone with this laptop. You will need to purchase an external microphone and plug it into the mic in socket.
Aug 30, 2007 | Dell Inspiron 6400 Notebook
Audio Technica Audio-Technica ATR-20 Professional Microphone Logo
106 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
