Question about Sewing Machines
Brother sewing machine. LS-2125i. Only motor running Help me please
    Problem Solver:
  • 13 Answers
There may be a belt that came loose inside the machine that runs the sewing machine it self.
Posted on Oct 14, 2013
3 Suggested Answers
  • 1116 Answers
SOURCE: appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Posted on Feb 21, 2010
  • 3 Answers
SOURCE: MY BROTHER MACHINE NO. LS-2125i THREAD BREAKING WHEN SEWING?
Thread brekage can be caused by several things but start simple by taking off the needle plate then thoroughly clean the sewing mechanism and add a few drops of oil, then check the threading is correct. replace the needle. Always use quality threads and make sure that the thread is not to heavy for the size of the needle (it should pass easily through the needles eye). check that the needle hole in the plate is not bent or damaged and peppered with needle marks, a damaged plate will cause many problems. Finally, make sure that the tensions are not too tight this can be a major cause of thread breakage especially if poor quality thread is used. ( check thread by breaking it by hand, it should offer good resistance to breakage, if it breaks easily then discard it. hope this is useful, best of luck.
Posted on Apr 14, 2010
Model LS-2125i..How do I access the bobbin
Make sure that the needle is fully up first and raise the presser foot. To access the bobbin, you need to remove the flat bed attachment that is at the front of the machine. This just rotates up and off the machine. Next rotate the shuttle cover down from the top of the cover. Now you can pull out the bobbin case towards you by the latch. This piece goes across the center of the bobbin case and to the right. Now you can remove an empty bobbin (if needed) and put the wound bobbin into the bobbin case to replace the bobbin.
For this procedure, the pictures in the manual may be clearer than the written description. See pages 14 and 15 (16 and 17 for the PDF) in the manual. Brother currently has the manual here: http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_LS_2125i_EN_1628.PDF . The LS-2125i support is here: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=LS2125i . Click on the Manuals & Documents page. Most Brother manuals and other documents can be found by searching here: http://www.brother-usa.com/Support/ .
I hope this helps.
Oct 28, 2016 | Brother Ls-2125i 10-stitch Portable Free...
Brother LS-2125i is 'freezing' up.
Personally it sounds like it could be a costly repair.A new Brother LS-2125i can be purchased online for about $80.00. Most sewing machine repair places charge upwards of $60.00 for a tune-up. So it's your call? Good Luck
Mar 09, 2014 | Brother LS-2125 Mechanical Sewing Machine
I'm looking for a brother ls-2125i operators manual
You can use the user manual from this link, just click HERE.
Sep 29, 2011 | Brother LS-2125 Mechanical Sewing Machine
Appearence of loop and no zigzag stich on ls-2125i brother
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Tension on ls 2125i
Quick google search found this, hope it helps:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000042/ls2220272015202125_iug03enfrespt.pdf
Aug 08, 2009 | Brother LS-2125 Mechanical Sewing Machine
LS 2125i haveing problems getting the top thread
I don't know about now, but in the old days you had to pull out about three inches of thread through the eye of the needle & hold it with plenty of slack while turning the wheel on the end of the machine slowly. Once the needle disappeared below the plate & then reappeared you could stop turning the wheel & slowly pull on the end of the thread you are holding to pull the thread from the bobbin up. Of course there must be thread on the bobbin spool & it must be some extra hanging out. (not broken off flush with the spool)
Jun 30, 2009 | Brother LS-1217 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
My brother 2125I sewing machine bottom thread keeps breaking
You may be sewing too fast, using cheap thread or your tension is off. All of which can cause your bobbin thread to break.
Jun 19, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
