Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
My sea gate hard drives data has just da, - Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
  • 22 Answers
Check out Hirens Boot CD that has many hard drive apps to check your drive for errors:
http://www.hiren.info/pages/bootcd
Posted on Oct 15, 2013
5 Suggested Answers
SOURCE: hard drive reported at zero bytes
see after teh utility named Partition Magic, It will solve these typoe of errors. Another cheap option is to try to format it with a vintage computes BIOS, HDD Formattion option, Not available in newer BIOS.
Tyr aldo Fdisk /mbr in the DOS PROMPT , booting with D.O.S. Ver. 6.0 Anyone remember this Operating system?
And the last option is to format the drive undel LINUX and thern get it back to Windows XP.
Posted on Jan 03, 2009
  • 10406 Answers
SOURCE: i have 60 GB
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy all your files to a brand-new disk-drive.
Posted on Nov 02, 2010
  • 389 Answers
SOURCE: my sea gate external hard drive can not open and
Using the windows disk management utility. This will tell you if the hard drive is connecting to the computer or if it is a hardware problem. Sometimes, power cycling the external and restarting the computer will help. Below are the directions for using this utility:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Please remember to post positive feedback if this solution was helpful. If not, please let me know and I will assist your further.
Thank You,
Brian
Posted on Jan 25, 2011
StuartB
  • 807 Answers
SOURCE: my seagate hard drive was said to have bad sector and have this terrible buzzing sound, is there any way i can recover my files on my hard drive?
You may be able to if you remove the drive and put it in to a portable drive enclosure. Then plug it in to another pc's usb port.
Posted on Feb 08, 2012
Hard disk is not detecting in my dvr
My sea gate 500 GB portable hard disk not detecting on computer
Mar 22, 2013 | EverFocus ECOR26416X1500 ECOR264 Series 16...
My seagate hard drive was said to have bad sector and have this terrible buzzing sound, is there any way i can recover my files on my hard drive?
Feb 08, 2012 | Seagate Computers & Internet
Our sea gate turns on but the bright light that shows when it is transferring data to the computer does not turn up. Is there any way to retrieve the information that I cannot access now? Thank...
Hi Nancy
It's hard to say from your description what the problem is but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Aug 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I plug my hard drive in my pc then its like..beeep beeep beeeep the whole time.it is the hard drive i know it for a fact.pls help.cant loose the data.its 500gb sea gate.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 24, 2011 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
I have a Sea gate free agent Go 250 GB. This was working fine till two weeks back. Now when I plug it in it makes some sort of noise but the comupter does not recongnize the external hard disk. I tried...
The noise is made by the rubbing of the reading head on the platters = mechanical defect.
There's nothing that can be done, by anyone , to fix it - it's dead and all the data on it is lost.
Dec 31, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have 60 GB sea gate sata hard drive i need to recover the data from hard drive but it is not detecting so please help me how can i detect the drive
Nov 02, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
Computer Doesn't See Freeagent Go 250 external drive
Uninstall all usb controllers from device manager and then restart your computer. Scan ur system with mcafee 8.5i
Jan 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
32 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
