Question about Biostar Motherboard 47-riobracket-78 Th55 Hd Tf8200 A2 I/o Shield
TH55 HD boot from usb drive - Biostar Motherboard 47-riobracket-78 Th55 Hd Tf8200 A2 I/o Shield
Hi, I have a Sony Vaio model SR150FN and I want to install a new TOSHIBA 500GB HD model MK5076GSX, the problem is that the BIOS can't see it, I put the HD in an external usb case, created a 500 GB...
> put HD into an external USB case
> the BIOS cannot see it
Correct. The BIOS does not see "external" USB devices.
However, see if you can "enable boot from USB devices",
and change the "boot order" to include USB devices.
You may need to remove the old disk-drive, and install the new disk-drive in its place.
Then, put the old disk-drive into the external USB case.
Install Windows to the new disk-drive, and then connect the external USB case,
and copy all the files from the "old" disk-drive to the "new" disk-drive.
Jun 06, 2011 | Computers & Internet
Computer will boot up with the external hard drive connected
if u dont want to bootup with external HD goto bios under boot device property first boot for {make it system intarnal HD}
Jun 26, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
May 03, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Wd and Seagate usb hard drives attached to computer Will not boot when WD usb hd on Seagate makes no difference
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
Apr 22, 2009 | Western Digital My Book Essential Edition...
How to use my usb port for booting my acer tm290 series?
First off your BIOS must have a "Boot to USB Hard Drive" option available. Then you need to configure the drive boot order; USB-HD -> CD -> IDE -> SCSI. Then the micro-drive must be formated with the "Boot" or "Active" partition flag enabled. If you are trying to boot Ubuntu there are several tools you can download that format the USB drive and set the boot flag for you.
Nov 28, 2008 | Acer TravelMate 290 Notebook
Sony Clie PEG-TH55
There are very limited original resources to get parts for obselete products. However you can check ebay.com time to time as frequently many sellers selling Sony Clie Parts.
Oct 02, 2008 | Sony CLIE PEG-TH55 Handheld
After software install of the new HD my computer will not boot if the HD USb cable is left attached. If I unplug the USB cable then the computer will boot up.
please check the boot priority in cmos setting...if its 1 priority given from usb drive than it will not boot till u unplug it.
Apr 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can't install xp - freezes
You need a CD/DVD USB drive.
Ask for one or use a HD 3,5" USB drive, open de HD USB disconect the HD and conect a CD drive, it will work like a CD USB drive.
Jan 10, 2008 | ViewSonic Tablet PC V1100
Biostar Motherboard 47-riobracket-78 Th55 Hd Tf8200 A2 I/o Shield Logo
50 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
