Linq li 520 - Computers & Internet
Install net framework
.net framework is a language pack platform as a user of Windows 8 you need framework 3.5 download via torrent isn't illegal it's a free software because i cant download this software completely by direct download
Direct Download :
http://www.microsoft.com/en-us/download/details.aspx?id=21
Via Torrent :
http://kat.ph/ado-net-3-5-with-linq-and-the-entity-framework-tqw-darksiderg-t2600070.html
caution
it's a web installer if any interruption install later
Apr 26, 2013 | ATI Computers & Internet
Tip
Troubleshooting wireless printing issue with Epson Workforce 630
Epson Workforce 630: Troubleshooting wireless printing issue with Windows 7
  1. Load your printer at least 5 sheets of plain paper.
  2. Press the Home button on the printer control panel to return to the Home Menu, then using the right or left arrow buttons select Setup.
  3. Use the down arrow button to select Network Settings, then press OK.
  4. Use the down arrow button to select Confirm Network Settings, then press OK.
  5. Press the Start Color and B&W buttons to print Network Status Sheet.
  6. Press Back button three times.
  7. Check the Printer IP address on the printed Network Status Sheet.
  8. Get the IPv4 address of your computer by following the steps below.
  • Click on Start > Search Program and files.
  • In the open box type CMD then press Enter.
  • In the resulting window beside the command prompt, please type IPCONFIG and you will see the following information.
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . . . . . . : fe80::c0a:f4ff:7d14:45f1%11
IPv4 Address. . . . . . . . . . . . . . . . . . . . : 192.168.1.5
Subnet Mask . . . . . . . . . . . . . . . . . . : 255.255.254.0
Default Gateway . . . . . . . . . . . . . . . : 192.168.1.1
  1. Compare the IP address of your printer and computer. Make sure that they are in the same Gateway.
Example:
Printer's IP address: 192.168.1.102
Default Gateway: 192.168.1.1
Computer IPv4 address: 192.168.1.5
If the Printer's IP address is 0.0.0.0, the DHCP is not providing the proper IP address to the printer. Contact support for the router or access point for assistance.
If the computer has different gateway, please contact the one who setup your network or your router manufacturer to check your network connection.
If the computer has same gateway, please ping the IP address of your printer. To ping the IP address of your printer please follow the steps below.
  1. Click on Start > Start Search.
  2. In the open box type CMD then press Enter.
  3. In the resulting window beside the command prompt, please type ping follow up by the Printer's IP address then press the Enter Key.
Example: C:\> ping 192.168.1.102
If ping result is Request time out or Destination Host unreachable, please ping the gateway or router IP address. Upon pinging the gateway or router IP address and still giving you the same result. Please contact the one who setup your network or your router manufacturer to check your network connection.
If ping result is packets: sent = 4, received =4, Lost = 0 (0% loss), please follow the steps below to readd the EpsonNet print port of your printer.
  1. In your computer click on Start > Devices and Printers
  2. Under Printers and Faxes, right click on your printer icon then click on Delete.
  3. Click on Microsoft XPS document writer icon then click on Print Server Properties.
  4. Click on Ports tab.
  5. Look for EpsonNet Print port that indicate the IP address of your printer. Select it then click on Delete Port.
  6. Click on OK.
  7. Click Add Printer then click Next.
  8. Select Local Printer attached to this computer and unchecked Automatically detect and install my Plug and Play printer then click Next.
  9. Click Create a new port and on Type of Port select EpsonNet Print Port.
  • If you see your printer select your printer, then click Next. Wait until the EpsonNet print port is configured, then click Finish when it's done.
  • If you don't see your printer, select Manual Setting then click Next. Enter the IP address of your printer then click Next . Wait until the EpsonNet print port is configured, then click Finish when it's done.
  1. Under manufacture select Epson and under printer select your printer then click Next.
  2. Select default Printer then click Next.
  3. Select do not Share this printer then click Next.
  4. Select Yes to print a test page then click Next.
  5. Click Finish.
on Nov 02, 2011 | Epson Office Equipment & Supplies
Tip
How to get back to yahoomail classic
Don't like the all new yahoo! mail?Want yahoo! mail classic back?Here's how to:
  1. You need to operate from a CRT monitor.
  2. Set the screen resolution to 800x600 pixels.
  3. Open your yahoo! mail account.
  4. Try to open any mails in your inbox.
  5. A screen resolution error window pops up and on this window is the option 'return to a previous version of yahoo! mail'.Click on that option.
  6. Enjoy yahoo! mail classic!
on Sep 25, 2011 | Yahoo Computers & Internet
Linq to sharepoint how to use
Hi, thanks for requesting my assistance with Sharepoint. What is it I help you with?
Jul 02, 2011 | Microsoft Office Professional 2007 Full...
Does this cost anything? Trying totake a battery out of an iphone.
If you have Electronics skills, you can do it by yourself, and also you'll need special tools for not damaging Iphone during the process, in the following link you can see a guide in PDF to do it:
http://www.ifixit.com/pdf/ifixit/guide_448_en.pdf
Feb 28, 2011 | Zip-Linq USB AC Adapter iPodiPhone...
Unlock my phone
Dear sir, How are you, I'm sending you some codes and I hope these codes will surely help you out.:)
Nokia Code & their function:
  • *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
  • #3370# Deactivate Enhanced Full Rate Codec (EFR)
  • *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
  • *#4720# With this Nokia code you can deactivate the Half Rate Codec
  • *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
  • *#9999# Phones software version if *#0000# does not work
  • *#06# For checking the International Mobile Equipment Identity (IMEI Number)
  • #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • *#147# This lets you know who called you last (Only vodofone)
  • *#1471# Last call (Only vodofone)
  • *#21# This phone code allows you to check the number that "All Calls" are diverted to
  • *#2640# Displays phone security code in use
  • *#30# Lets you see the private number
  • *#43# Allows you to check the "Call Waiting" status of your cell phone.
  • *#61# Allows you to check the number that "On No Reply" calls are diverted to
  • *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
  • *#67# Allows you to check the number that "On Busy Calls" are diverted to
  • *#67705646# Phone code that removes operator logo on 3310 & 3330
  • *#73# Reset phone timers and game scores
  • *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
  • *#7760# Manufactures code
  • *#7780# Restore factory settings
  • *#8110# Software version for the nokia 8110
  • *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
  • *#94870345123456789# Deactivate the PWM-Mem
  • **21*number# Turn on "All Calls" diverting to the phone number entered
  • **61*number# Turn on "No Reply" diverting to the phone number entered
  • **67*number# Turn on "On Busy" diverting to the phone number entered
    Good Luck. :)
Dec 16, 2009 | Motorola Mobility E770 Cellular Phone
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
