Question about HP dc7700 PC Desktop
Monitor not supported
Have a dc7600 monitor is fine. But just got a dc7700. Hooked up everything. Load XP. Bootup. XP Screen appears then Screen goes blank then this icon floats on the screen (monitor not supported). Run restore and diagnostics screen is fine. Reboot XP screen appears then goes away icon comes back monitor not supported, you hear XP in the back ground but no sceen. Went back to my dc7600. Any thoughts on this issue.
  • HP Master
  • 3,866 Answers
Well the monitor not being support is not the issue. the issue is the video card cannot produce a signal that is supported for the monitor. Its doing this to let you know also to lower your resolution because the monitor will pop if the resolutions is to high. the monitor itself does not matter if you had Vista as lond as the monitor agree with the signal your cool if it don't it will do this. Try lowing the res using another monitor then put the orginal back on and you should be good.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 24, 2009
POS X Evo TP1 A1N screen appears to be off, but power is on
first of all check your monitor. it would be the best if you can plug some other monitor just to check... if your monitor is OK then probably you VGA is bad and you`ll have to change it.
Dec 14, 2013 | POS X POS-X EVO TouchPC (PXI-EVO-TP1-A1N)...
FPD1930 gateway monitor powers up then a small box saying power save mode appears then it just goes black what's wrong with it
Hi. power save mode being displayed by the monitor could be caused by 3 things.
1)VGA cable to monitor is unplugged - check connections at computer and monitor
2)video card has been partially dislodged from motherboard socket. -remove computer cover and ensure video card is firmly pushed down into motherboard socket - do not use excessive force.
3)Monitor does not support video settings on the computer. - to fix on PC, turn on computer and press F8 button a few times during bootup - Windows will go to bootup screen - select SAFE MODE and hit enter. follow onscreen instructions - dont worry about weird colours and huge desktop icons - this is simply to get you going. Right click on desktop, select PROPERTIES>SETTINGS TAB. select screen resolution 1024*768 0r lower, select Apply or Ok. Now restart your machine
Dec 08, 2012 | Computers & Internet
When I attach an external monitor the F5 key does not toggle to the external monitor although the external monitor shows the windows logo at bootup and then goes to test screen.
goto your control planel select display settings on the notebook to adjust the selected monitor. Than test monitor 1 or 2. What OS are you using it is alittle diffence. XP or vista; vista has personalization and xp go into display properties.
Jul 18, 2009 | Acer Aspire One PC Notebook
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Monitor freezes up with multicolor wording or distorted images
Sounds to me like a few possible things...
1) Bad connection to the monitor, check the cable connection, if you see or suspect any damage, buy a new monitor or test with a friend's monitor.
2) Video card could be bad, if it has a video card, you could simply buy a new card to see if it will fix the problem. If the video port is attached to the motherboard (meaning onboard video), the motherboard could be damaged.
3) The motherboard could be bad. Sometimes fried motherboards will garble the screen like this on bootup.
Mar 25, 2009 | IBM Computers & Internet
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to http://support.gateway.com/support/default.aspx input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Sean
Mar 16, 2009 | Computers & Internet
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
How do I increase the size of my desktop and remove the blue border?
There are three size settings you can choose from, Normal, Wide and Zoom. Try changing it using the 'Size' button on the remote or by going into the On Screen Display (OSD) settings. If you don't have a manual you can get one here. Hope this helps.
Mar 14, 2008 | Samsung 192MP (Silver) 19" LCD Monitor
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
HP dc7700 PC Desktop Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
