Question about Toshiba 50H72 50" Rear Projection Television
I have a Toshiba 50H72. When I initally start the tv up the picture scrolls up. I have to wait for anywhere from half an hour to an hour for the picture to clear up and continually turn the tv on and of. Now the screen flickers there is a line that pops up ocasionally on the right side vertically and horizontally there are lines at the top that never seem to go away, what can I do?
  • 3 Answers
I am pretty sure u need to go to the menu and check your v chip or a button on the tv that starts with the letter v that will control the picture
Posted on Apr 24, 2009
Only the bottom half of the screen comes on
Is it Toshiba 50H72 and what does tv show in upper half of screen?
These info will help me to diagnose the problem.
Thanks.
Aug 12, 2011 | Toshiba 50H72 50" Rear Projection...
Picture size does not work
Unplug the power cord for about an hour or more and provide supply to the tv .
At times the power supply can cause this problem .
If you have any substances generating EM waves in and around tv remove it .
Oct 15, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to i change the picture from antenna to cable?
TV/CABLE function
1 Press MENU, then press S or T until the SET UP menu appears.
2 Press up/down arrow button on remote until "TV/CABLE" is highlighted.
3 Press to highlight either "TV" or "CABLE", whichever you use.
Hope these info will help you.
Let me know if you need user manual free copy of Toshiba 50H72 tv.
Thanks.
Jan 05, 2011 | Toshiba 50H72 50" Rear Projection...
Power but no picture
the Y-SUS BOARD is for picture in tv.if the picture is not coming or not proper the Y-SUS board needs replacing .but if the picture is blurry or with linings reparing helps.but in your case the tv does not turns on with y-sus board connected only error led comes on.this means y-sus board needs replacement.
you can get it from www.partstore.com
if you are not familiar with replacing the y-sus board its advisable to get it done by local tv repair technician familiar with your brand/model.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Oct 26, 2009 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72
Just finished one of these here at the shop. There is a service bulliteen from toshiba on these. There is a series of 11 16 microfad service mounted caps on a cuircit board called the hypermodule... basically the main signal processing board. that needs to be replaced. very very tricky soldering. very dificult repair. We charge about 250 in labor pluss the parts
Mar 04, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 rear projection TV. NO Video
Bad caps and solder connections, especially in around the 9v regulator just about center of the defection circuit... Not a terribly expensive job and certainly worth the repair if the cabinet is in good condition...
Bill
Jan 13, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72
The Hyper Module Is Defective / It Is Located Behind The Jack Panel On The Signal Board.
More specifically the 11 16v/10mf caps on that board need to be replaced... Not expensive, I do them for under $100.00 dollars..
Bill
Dec 17, 2007 | Toshiba 50H72 50" Rear Projection...
Flashing picture when start up
What i would do id purchase a can of freeze from radio shack
wait till the picture is good then freeze one ic at a time till the problem shows up, once it shows up let it warm back up and refreeze to make sure you got the correct part.
found this on anther site:
My first guess is an electrolytic cap in the main power supply and/or a voltage regulator that feeds the deflection amplifiers.
The cost of repair is not much; the greatest challenge is finding the bad cap because there are so many of them and scattered through out the sections.
If you have a scope and can look at some waveforms and voltages around the deflection and power supply feeds you may be able to zero in on it right away
Oct 11, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 Rear Projection Television
no you wont be able to fix over the phone it requires replacement of the stk packs
Dec 04, 2006 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
168 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
