Question about Saws
How do i replace the pull cord on my stihl cut off saw
It is a stihl cut off saw, model 762 or 760
  • 4 Answers
It is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
Posted on Apr 24, 2009
Stihl ts pull string replace
I've added the TS410 brake down as they're all basically the same and you haven't stated the model to which you're referring.
http://www.mediafire.com/download/dk8dipzr69pksrk
Jan 30, 2014 | Stihl Saws
Husqvarna pull cord
remove the recoil housing and add an extra turn on the recoil cord on the spool to take up the slack.
Nov 27, 2013 | Stihl Saws
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Stihl ts 400 has stopped working and sounds rough when pulling the cord
Sounds bad, the only answer here is to pull the cylinder off and check the condition of the internals, if there is a lot of dust behind the filter and into the back of the carb the engine is going to be in need of rebuild.
Mar 25, 2013 | Stihl Ts 410 420 Cut Off Saw...
Petrol stihl
Stihl machines have a plastic pawl in the rope pulley, a small r clip retains the pulley and creates some friction on the pawl, as the pulley turns the clip tries to stay still due to the tention this in turn drags the pawl out and into the flywheel drom, so you either do not have enough tention on the r clip, or the small plastic dog has broken.
Feb 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Replace pull cord
i roadworks63. Pull off the right side cover to expose the recoil, remove the rest of the rope. Now rewindthe pully c.c.wise until it stops then release it just enoughto align the rope holes,use a C clamp to hold the pully from unwinding. Insert the rope enough to tie a knotHeat the knot to make it hard,now slowly let the pully re..turn or unwind tieon the handle. You are home free.
May 17, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Saws Logo
1,073 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
