When running the program at 40 for cotton, the program gets stuck with around 30 min left. It just keeps slowly spinning without changing the time.
SOURCE: Candy Activa Smart 1300 AA
Many thanks had already done this and all is working fine now fingers crossed!
SOURCE: a t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
SOURCE: candy aqua 1000
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve.
SOURCE: how do i get a new instruction manual for my candy
Here you go:
http://service.candy-domestic.co.uk/manuals/
download it online as pdf.
remember to rate me!!!
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
